Activity › Forums › DSLR Video › DSLR that shoots in PAL
  • DSLR that shoots in PAL
    Posted by John Kis on February 4, 2010 at 4:29 am
    Hi guys – great new forum!
    I’m in Australia and was really interested in this video DSLR thing – mainly because I can get great narrow depth of field with an SLR. However, my understanding is that most still cameras shoot in 30fps progressive. Is this true? Can you get DSLRs that shoot in PAL (25fps, interlaced) – it would be great if I could import to PC in DV PAL.
    Jiri Fiala replied 16 years, 7 months ago 9 Members · 11 Replies
  • 11 Replies
  • Richard Harrington
    February 4, 2010 at 4:34 am
    Many cameras are starting to support multiple frame rates. Look at the Canon 7D for example
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Dieter Depypere
    February 4, 2010 at 4:42 am
    We’re all waiting for all the framerate firmware update by Canon. If they can make it happen for the 7D and 1DMarkIV, why are they waiting so long?
    thirdeyed gcv – Dieter Depypere
  • Lance Bachelder
    February 4, 2010 at 6:19 am
    The Canon 7D let’s you switch between NTSC & PAL on the same model. You can then select framerates for the chosen standard such as 25 or 50fps for PAL and 29.97 and 60fps for NTSC along with 23.976 for 24p workflow.
    Lance Bachelder
    Southern California
  • Robert Mueller
    February 4, 2010 at 8:34 am
    Hi John,
    the Panasonic Lumix GH-1 is 25 FPS at 1920×1080 and 50 FPS at 1280×720. It records 17 Mbps AVCHD.
    Robert
  • Bruno Perosa
    February 4, 2010 at 8:42 am
    to start we must say that HD is something and Pal/Ntsc is something else.
    Frame rate is a different subject matter, all the new screens (LED’s, LCD’s, Plasmas) are working progressive while interlace is legacy of CRT’s. Canon is going to release a new firmware for the 5D with the possibility to record 25, very soon.
    EX3, MBP17″2.93GHz, FCS2, Media100, BtcSP, DVcam
  • Jiri Fiala
    February 4, 2010 at 9:07 am
    I have a 7D and it definitely doesn’t record PAL, not in Europe anyway. It allows me to switch between 1080p, 720p and 640×480.
  • Norman Pogson
    February 4, 2010 at 1:12 pm
    The Pal NTSC thing is confusing, because the Canon 7D does switch from pal to ntsc, but it is only for playback on a tv.
    The other poster is correct, the Canon HD DSLR’s shoot progressive and the 7D at the moment has the most choice of frame rates, including 60fps which will give some cool slow motion when you adjust your fps in an editor to say 24fps.
    For the OP the Canon 7D would be a good choice.
  • Andrius Simutis
    February 17, 2010 at 5:53 am
    “The Pal NTSC thing is confusing, because the Canon 7D does switch from pal to ntsc, but it is only for playback on a tv. ”
    Nope, you can shoot PAL too. You can’t see those frame rates when you’re set to NTSC, but once you go into the MENU and set it to PAL, then you’ll have access to the PAL framerates, 720P @ 50fps and 1080 @ 25fps. And when you’re in PAL mode you won’t see the NTSC framerates.
    I don’t think the 5D has this, yet. But the PAL framerate was one of the big selling points for the 7D in EU.
  • Jiri Fiala
    February 17, 2010 at 7:51 am
    I’m sorry but I own 7D in EU and PAL is definitely NOT an option. Nor is full NTSC. There is only 1080/24, 1080/25, 720/50 and 640×480.
  • Norman Pogson
    February 17, 2010 at 12:13 pm
    Andrius is right, if you select pal it opens up the pal frame rates
    My Canon 7D Blog
