Activity Forums VEGAS Pro DSLR Sync Issues
  • DSLR Sync Issues
    Posted by Thomas Roberts on December 17, 2010 at 6:08 pm
    Hi guys,
    I’m shooting with a Canon DSLR. 1920×1080 30P. I am using Pleural eyes to sync my audio+ video. I’ve used the match media settings, but I seem to be getting some audio sync problems. Using an H4N to do double system sound
    I am rendering to 1920 x 1080 29.97 (match media). Quick Time seems to be out of sync, VLC media player, it looks great in sync and appears to be in Sync. On Vimeo it appears to be out of sync
    Here is a clip:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Some cool people I follow on Twitter @mostlylisa, @JoeTheProducer, @bruce_patterson, @KhalidMohtaseb, @Dugdale
    T
    Thomas Roberts replied 15 years, 8 months ago 1 Member · 1 Reply
  • Thomas Roberts
    December 20, 2010 at 6:35 am
    Ok, did some research and found my problem solved…
    Audio frame rates matter too!
    Another audio trick I have learned the hard way is how to use audio frame rates. Yes, audio has a frame rate, just like video (who knew?) – and it’s important you get the right one when recording audio onto a separate device. Otherwise, your audio slowly starts to slip out of sync – a pain when you’re trying to edit!
    A bit of research led me to this conclusion: set your camera to film at 24p and your audio to record in .wav form at 48khz. All good audio recorders should let you adjust these settings. This way, the frame rates match perfectly!
    found at https://blog.vjmovement.com/?p=322
