Activity › Forums › DSLR Video › DSLR Staedycam
DSLR Staedycam
Posted by Marc Lucas on November 7, 2011 at 2:31 pmHi
Any suggestions on an entry level steady cam for DSLR shooting. Something to get used to that way of shooting?
Marc Lucas replied 14 years, 10 months ago 5 Members · 6 Replies -
Errol Lazare
November 7, 2011 at 5:47 pmBoth the steadicam merlin and glidecam hd2000 are good options. i would recommend renting them first from a local video rental house so you can determine which is right for you. It takes quite a bit of practise to get good at so practise lots, run with it, and master it. I started with a glidecam smooth shooter which incorporates the glidecam 4000 sled and also an arm and vest. Last year i upgraded to the steadicam pilot and it is amazing. I find that the glidecam is good but nothing beats a steadicam. It is in my opinion perfect engineering.
Errol X. Lazare
EXL Films
http://www.exlfilms.com -
Brent Dunn
November 8, 2011 at 7:09 pmglidecam.com
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.netSony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut StudioHP i7 Quad laptop
Adobe CS-5 Production Suite -
Phil Balsdon
November 8, 2011 at 10:20 pmIf you start with a handheld Steadicam Merlin you can upgrade later with the vest and arm package.
You can then upgrade the vest and arm package to the compatible Steadicam Pilot sled.
Eventually you’ll be addicted to Steadicam and can mortgage your house and buy a Steadicam Clipper or Ultra.
To use the camera as a handheld on a Merlin you do not need to remove it from the Merlin, just fold the base and it makes a good hand grip under the lens.
For tripod mounting they also supply an adaptor for fast change overs that saves fiddly re-trimmnig when going back to the Steadicam Merlin.Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://philming.com.au
https://www.steadi-onfilms.com.au/ -
Marc Lucas
November 11, 2011 at 11:21 amJust so happens I saw a demo video of that yesterday I like the look of that!
