Activity › Forums › Apple Final Cut Pro Legacy › DSLR ProRes 422 and HDV
  • DSLR ProRes 422 and HDV
    Posted by Frank Giardina on January 15, 2011 at 1:53 am
    Hello All….
    Quick question(s). Mixing 1080 HDV footage and 1920 x 1080 DSLR footage transcoded ProRes 422. I’m not going to capture the HDV ProRes… I’m not setup for that with space at this time. So I’m capturing HDV-1080p24 FireWire Basic.
    With that being said, I have two choices for sequence settings. One have the sequence match the ProRes 1920 x 1080 OR go with the HDV sequence setting. In each case I’ll end up with 720 x 480 when I author my DVD. I’ve been told I should base it on which footage I will use more of. That seems like the right answer, but with quality in mind…..
    Here’s my questions:
    1) Which sequence setting should I go with in order to have the best quality?
    2) What compressor setting in the Sequence Settings based on #1.
    Thanks!!
    Frank Giardina
    17 Video Production
    Frank Giardina replied 15 years, 8 months ago 2 Members · 3 Replies
  • Shane Ross
    January 15, 2011 at 5:16 am
    [Frank Giardina] “1) Which sequence setting should I go with in order to have the best quality?”
    ProRes 422 1920×1080.
    [Frank Giardina] “2) What compressor setting in the Sequence Settings based on #1.”
    ProRes 422 1920×1080…frame rate to match your footage.
    [Frank Giardina] “I’ve been told I should base it on which footage I will use more of. “
    In this case, when mixing formats, ProRes is the better choice, as HDV is a GOP format, and putting non-GOP footage into a GOP formatted sequence leads to lots of crashing.
    Shane
  • Frank Giardina
    January 15, 2011 at 5:33 am
    Thanks Shane, I appreciate your wisdom. I’ve already made the change. I pay close attention to your advice on the forum.
    Thanks Again!!!
    Frank Giardina
    17 Video Production
  • Frank Giardina
    January 15, 2011 at 8:03 pm
    Hi one last question.
    Using a ProRes Sequence Settings, as noted below, forces my HDV footage to upsize to 133.33. Is that safe for HDV footage as far as retaining quality? 33% seems like a lot to me.
    Help 🙂
    Frank
    [Frank Giardina] “I’ve been told I should base it on which footage I will use more of. ”
    Frank Giardina
    17 Video Production
