Activity Forums VEGAS Pro DSLR .mov files have no video
  • DSLR .mov files have no video
    Posted by Mary Waitrovich on April 19, 2011 at 1:53 am
    I received a bunch of .mov files on a mac formatted drive. I was able to mount the drive and copy the files to my PC using the utility Macdrive.
    Vegas 10 can only see the audio, no video. Updated Quicktime player opens the file but there’s only audio, no video. When I try to add a file to Cineform NeoScene to convert, I get the error message that the format is not supported.
    The camera is a DSLR, the Panasonic GH2. She records onto an Optima SDHC HD card and imports the files to a mac computer using Final Cut Pro’s Log and Transfer tool, which then converts them into .mov Quicktime files.
    I’m thinking I might need to import the files using her camera into Cineform on my PC. It would be easier if I could either convert these mov files into something I can use or have her export them from FCP in a format I can use. I want the highest quality as we are doing these tests for a possible feature length piece.
    Your expert advice is, as always, much appreciated.
    Mary Waitrovich
    Media Plus You, LCC
    http://www.mediaplusyou.com
    John Rofrano replied 15 years, 4 months ago 2 Members · 3 Replies
  • John Rofrano
    April 19, 2011 at 1:04 pm
    [Mary Waitrovich] “I’m thinking I might need to import the files using her camera into Cineform on my PC. It would be easier if I could either convert these mov files into something I can use or have her export them from FCP in a format I can use. I want the highest quality as we are doing these tests for a possible feature length piece. “
    If you want the highest quality, get the Mac out of the workflow. Take the original files from the camera and convert them to CineForm which will be easier to work with.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mary Waitrovich
    April 19, 2011 at 8:35 pm
    Thanks John, as usual, your advice did the trick. I copied the files from the camera card to the PC, and Cineform NeoScene converted them nicely.
    Mary Waitrovich
    Media Plus You, LCC
  • John Rofrano
    April 19, 2011 at 11:15 pm
    Glad that worked for you. Always get the native formats whenever you can. This will always work best on a PC.
    ~jr
