Activity Forums DSLR Video DSLR H264 convert
  • DSLR H264 convert
    Posted by Antoine Julien on February 24, 2010 at 3:22 am
    Hi people of the Internet
    I just shot a corporate video with the Canon 7d ans had a few questions on my mind.
    1- I usually use Mpeg Streamclip to convert my H264 files into ProRes HQ. Is it the good way or will I get better results doing it a different way.
    2- My audio was recorded independantly on a zoom h4 recorder and will use pluraleyes to re-sync it aftewards. Since we shot a considerate amount of footage I was thinking of editing with my ProRes files with camera sound first, and then replace the audio on only the files i will
    use in my final edit (by replacing them in my capture scratch at he end) Is it a good idea or am I heading in the wrong direction.
    3- Finally, if proceed this way I will end up compressing my files a two occasions (first H264 to Pro Res, and then Pro res with camera sound to Pro res with good clean sound), am i risking losing quality in my images?
    My question is actually if export (with the “export quicktime movie” option)in the same codec multiple times am I losing a lot of quality in the long run or since I am sticking with the same codec Final Cut does not compress it in any way.
    Thanks in advance for your answers
    Antoine
    Antoine Julien replied 16 years, 6 months ago 4 Members · 6 Replies
  • Richard Harrington
    February 24, 2010 at 4:11 am
    1. In my tests MPEG Streamclip about 90% as good as Compressor (and MUCH faster)
    2. Sync first… much easier to do with your clapboard and slate. Plural Eyes is great… but works best when your clips and your audio run longer. trying to sync up a bunch of short edits is not desireable and will make your audio tracks a mess.
    3. No need to compress again. Transcode and sync.. then edit.
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Lance Bachelder
    February 24, 2010 at 4:36 am
    I would stick with Compressor – if Streamclip causes even a 10% loss as Richard stated why use it? Just encode a clip each way and see for yourself if the difference matters. I personally didn’t like the results with Streamclip so I don’t use it – I run everything through Compressor to Pro RES HQ.
    As far as audio goes I cut the same way – cutting in clean audio as I finish sequences – it’s a pain either way but why sync takes I’ll never use.
    You can always transcode to ProRES 444 for final master if you feel you are losing something with HQ, but I think HQ holds up pretty well.
    Lance Bachelder
    Southern California
    February 25, 2010 at 4:42 pm
    It’s not noticeable on all footage… and its MUCH MUCH faster
    Both are good… and it depends upon what your needs are.
    If you have all the time in the world… go for quality. If you got a deadline, go for great and free.
  • Brian Mccartney
    February 25, 2010 at 5:49 pm
    Richard, just curious. How do you have Compressor set up on your machine? I have a quick cluster set up on my machine (8 core mac pro) and I see comparable encoding times for the same codec, frame rate, and frame size.
    I do see people using MPEG Streamclip quite a bit for this kind of transcoding so I am wondering if I am missing something here.
    thanks!
    February 26, 2010 at 1:18 pm
    Make sure you tell MPEG Streamclip to allow multiple tasks… that will speed it up
  • Antoine Julien
    March 1, 2010 at 4:01 pm
    Thx for the answers guys
    Think i will try out compressor this time.
    However i’m not so familiar with it.
    Do you have a good tutorial to recommend
    on how to do massive batch transfer?
    Thanks again
    Antoine
