Activity Forums Apple Final Cut Pro Legacy DSLR footage mix with DVCProHD
  • DSLR footage mix with DVCProHD
    Posted by Gerret Warner on May 4, 2011 at 4:31 pm
    I have a project mostly shot on DVCProHD 720p60/23.98 and I have additional footage from a Canon DSLR shot at 1080/23.98.
    Should I use Compressor to transcode toProRes 422 and edit on a ProRes 422 timeline?
    Shane Ross replied 15 years, 4 months ago 2 Members · 3 Replies
  • Shane Ross
    May 4, 2011 at 4:37 pm
    How big of a majority is the footage? If it’s 90% DVCPRO HD, and 10% DSLR, I say convert the DSLR to ProRes, but edit in the DVCPRO HD sequence.
    Shane
  • Gerret Warner
    May 4, 2011 at 4:39 pm
    Thanks for the quick response.
    I don’t know what the percentage will turn out to be, but I’d guess it will be DVCPro 75%.
    Is there much difference between editing in DVCPro and ProRes with these mixed sources?
  • Shane Ross
    May 4, 2011 at 4:52 pm
    DVCPRO HD is 8-bit, and anamorphic. ProRes is 10 bit and full raster. Both are 422.
    ProRes is the better option, but it all depends on what you will be delivering, and how much rendering ou want to do. You can work fine without rendering, but before you export or to watch at full quality, you’ll have to render.
    Shane
