Activity Forums Adobe After Effects dry ice cascading effect using TC particular.
  • dry ice cascading effect using TC particular.
    Posted by Justin Mettam on August 22, 2016 at 3:00 am
    I would like to create a dry ice cascading effect. I am using Trapcode Particular but maybe I should be using Trapcode Form?
    First problem is I need the particles to flow over a long edge. Currently I need to play an emitter traveling across screen to create the long edge. I would like it to emit from a constant line.
    Second problem is I would like the dry ice effect to shoot out and then fall down. Currently it emits in all directions and I use wind and gravity to pull it down.
    Thanks in advance.
    Kalleheikki Kannisto replied 10 years ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 22, 2016 at 7:20 am
    Box emitter with proportions like 1000x10x10 would work for the emitter. Motion path (particle animation following the motion path of a light) is perfect for this type of animation.
    Also, a bit of a fade-in time for the turbulence field helps, as well as making the turbulence field move down over time to correspond with falling particles.
    10453_dryice.aep.zip
    Senior Graphic Designer
