Activity Forums Adobe After Effects Expressions DropShadow and Directional Blur to reverse orientation to path
  • DropShadow and Directional Blur to reverse orientation to path
    Posted by Pedro Amaral on July 4, 2018 at 10:16 am
    I have an animated solid with orient to path.
    A copy of this solid has a Drop Shadow / Directional Blur effects, is there an expression that could read the orientation to path of the solid and reverse it? As if this solid is leaving a trail behind.
    Any input will be much appreciated.
    Thanks in advance!
    Dan Ebberts replied 8 years, 1 month ago 2 Members · 1 Reply
  • Dan Ebberts
    July 4, 2018 at 12:53 pm
    Something like this will give you the angle of the X axis of your layer within the comp, but I’m not sure if helps do what you want:
    v = toCompVec([1,0,0]);
    radiansToDegrees(Math.atan2(v[1],v[0]))
    Dab
