Activity Forums Apple Final Cut Pro Legacy Dropping frames while capturing HD CAM
  • Dropping frames while capturing HD CAM
    Posted by Encoding on August 15, 2006 at 2:06 pm
    hello there
    i’m quite a newbie to all this hd stuff so aplogies upfront if i ask something ‘stupid’.
    i’m trying to capture a 15secs clip of an hd cam tape (1080i/50) in fcp.
    here are the settings i’m using:
    Sequence Preset: Blackmagic HDTV 1080i 50 – 10 Bit
    Capture Preset: Blackmagic HDTV 1080i 50 – 10 Bit
    Device Control Preset: Blackmagic HDTV 1080i 50
    Video Playback: Blackmagic HDTV 1080i 25Hz – 10 Bit (1920 x 1080)
    after logging the clip it starts to capture the first few seconds but then i get an error message – to be exact – i’m getting two different kinds of messages.
    locating timecode break – which definitely can’t be as the tape doesn’t have an tc break
    but this message doesn’t even come up all the time – a few times i got the error message about fcp dropping frames while capturing.
    after i got this tc break message i changed the Device Control setting to ‘Non-Controllable Device’ and captured the source ‘live’.
    but even with that i got the ‘Dropping Frames’ error message!
    it captures a few seconds of the clip (which by the way look really nice) but not more than that!
    i have been spending all morning on this trying to solve it but no luck – i just don’t have any clue at all.
    any help is greatly appreciated
    thanks a lot in advance
    fahaad
    Dave Allen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Dave Allen
    August 15, 2006 at 5:57 pm
    Are your drives fast enough to sustain 1080i playback and record? You can’t exactly record this to a firewire drive without it choking after a fews seconds.
