Activity Forums Adobe Premiere Pro Dropping frames while capturing from miniDV Cam.
  • Dropping frames while capturing from miniDV Cam.
    Posted by Ben Cruz on August 20, 2006 at 9:08 pm
    I’m trying to capture some footage using Premiere Pro 1.5 and it keeps dropping frames.
    I’m using a miniDv Canon ZR400 (NTSC) on a PC with 1Gb of Ram, 2.6Ghz processor, through firewire 400.
    I’ve checked every possible cause I could remember of:
    – Checked the specs of my hard drive and its more than enough
    – Turned off the preview while capturing and still didn’t work
    – Tried connecting the camera through the external HD and save the footage in it
    The most akward thing is that I managed to capture footage with the exact same PC but with a PAL miniDV cam and
    it did’t drop any frames.
    Anyone got any solution for this?
    I appreciate the attention on this matter.
    Cheers
    -David
    Ben Cruz replied 20 years ago 2 Members · 2 Replies
  • Vince Becquiot
    August 21, 2006 at 12:30 am
    Download a free program called Windv: https://windv.mourek.cz/
    Premiere capture is picky on a lot of things, including fragmented drive, whether you a using a master or slave drive for capture, and what program is running in the background, including antivirus.
    Windv buffers the capture and I’ve never had a dropped frame since.
    Vince
  • Ben Cruz
    August 21, 2006 at 8:35 am
    hey that’s great, thanks a lot for the tip.
    I’ll give it a try right away.
    David
