Activity Forums Apple Final Cut Pro Legacy Dropping frames while capturing from HDCAM
  • Dropping frames while capturing from HDCAM
    Posted by Encoding on August 16, 2006 at 9:55 am
    hello there
    i’m quite a newbie to all this hd stuff so aplogies upfront if i ask something ‘stupid’.
    i’m trying to capture a 15secs clip of an hd cam tape (1080i/50) in fcp.
    here are the settings i’m using:
    Sequence Preset: Blackmagic HDTV 1080i 50 – 10 Bit
    Capture Preset: Blackmagic HDTV 1080i 50 – 10 Bit
    Device Control Preset: Blackmagic HDTV 1080i 50
    Video Playback: Blackmagic HDTV 1080i 25Hz – 10 Bit (1920 x 1080)
    after logging the clip it starts to capture the first few seconds but then i get an error message – to be exact – i’m getting two different kinds of messages.
    locating timecode break – which definitely can’t be as the tape doesn’t have an tc break
    but this message doesn’t even come up all the time – a few times i got the error message about fcp dropping frames while capturing.
    after i got this tc break message i changed the Device Control setting to ‘Non-Controllable Device’ and captured the source ‘live’.
    but even with that i got the ‘Dropping Frames’ error message!
    it captures a few seconds of the clip (which by the way look really nice) but not more than that!
    i have been spending all morning on this trying to solve it but no luck – i just don’t have any clue at all.
    any help is greatly appreciated
    thanks a lot in advance
    fahaad
    Tmr Encoder replied 20 years, 1 month ago 3 Members · 2 Replies
  • Kevin Monahan
    August 16, 2006 at 7:19 pm
    What kind of drives are you using for capture?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Tmr Encoder
    August 18, 2006 at 12:54 pm
    Unfortunately I don’t have a RAID to use so I’m using the internal 372GB (Serial-ATA) drive.
    Here is some more info on the MAC I’m working with.
    CPU Type: Power Mac G5 (3.1)
    Number of CPUs: 2
    CPU Speed: 2.7 GHz
    L2 Cache per CPU 512 KB
    Bus Speed: 1.35 GHz
    Could it be that without the use of a RAID Array I won’t be able to to 1080i stuff?
    Would I then by any chance (with my current equipment) be able to capture 720p content?
    Or will that also be impossible?
    Thanks for your help.
    Regards
    Fahaad
