Activity › Forums › Blackmagic Design › Dropping frames in PPro 1.5.1 with DL Extreme
  • Dropping frames in PPro 1.5.1 with DL Extreme
    Posted by Nikola Stefanovic on April 18, 2005 at 9:15 am
    P4P800E-deluxe (intel 875), P4 3.2, 1GB ram and 2x250GB Raid (maxtor drives on primary SATA), radeon 9600XT
    Windoxs XP Pro + SP2 + BMD 4.8.1 + PPro 1.5.1
    BMD disk speed test about 110fps for PAL 10Bit 4:2:2
    In deck control utility everything plays perfect, without drop frames.
    In PPro 8 Bit works fine, but 10 Bit frequently dropping frames… Why?
    Disk speed test is OK, playback from deck control is OK, just PPro have problems.
    Nikola Stefanovic replied 21 years, 5 months ago 3 Members · 3 Replies
  • Yves De muyter
    April 18, 2005 at 10:18 pm
    You need at least 64-bit 66Mhz PCI busses. Your motherboard has only 32-bit PCI busses. Don’t be fooled by the size of the DeckLink card.
    It’s not the bits that count, but the speed of the PCI-bus (66 mhz instead of the 33mhz of a regular 32-bit PCI). BMD should have made the boards 1 inch bigger, so an empty part would fit in the 64-bit part of the bus, it would make support much easier.
    For a timeline to play, you need several channels of video. That’s why you can get away with it using Deck Control but not with PPro.
    -Yves
  • Baz Leffler
    April 19, 2005 at 12:28 am
    I have an almost identical system to yours with a DL Extreme. What I have found is that the sound playback on the timeline can cause playback problems (strangely the video gives way to the sound so the video skips frames and goes out of sync)
    My workaround is to render out the complete sound mix to a wav file and then bring it back into the timeline and mute all the others. Even better if you put the wav file on a separate drive to the video.
    I have found the advantage of ‘video giving way to audio’ is when exporting to tape. I always set my sequence timecode to the same as the timecode on the tape I am exporting to. Then I can compare timecode cut points on the timeline with those on the master videotape. If they are not identical then I know a drop frame occurred somewhere. Having the same timecodes also helps in doing pick up edits.
    Now the ‘dropframe somewhere’ can be a problem. It is a matter of going back in the timeline comparing it to the master until you find where it is back in sync. (go back a minute at a time to isolate the precise point)
    A technique I use occasionally is to create an EDL prior to the export to tape and while exporting I put a VHS across the decks timecode displayed output and randomly play it back checking the cut points against the EDL. Obviously you wouldn’t bother with a short playout but I recently completed 3 x 90 min workout videos (boooorrrrring!) and wasn’t going to sit thru the whole lot checking for drop frame and lip sync errors; and I did have to stop a few times and pick up an edit when I detected an error on the VHS playback.
  • Nikola Stefanovic
    April 19, 2005 at 7:59 am
    Thanks Yves and BazinoZ, but i read posts from people with same MB as me. They dont have these problems …
    https://www.creativecow.net/forum/read_post.php?postid=111052396473972&forumid=124
