Activity › Forums › Apple Final Cut Pro Legacy › dropping frames
dropping frames
Posted by Lee on July 13, 2005 at 1:49 pmHi Guys
Using FCP 5 with a DP 2.7GHZ and Lacie firewire extreme drive(88mbs).
Everytime I play the footage it says it drops frames
Files are saved on the external drive
It’s set to dynamic RTAny thoughts?
Paul
Walter Biscardi replied 21 years, 2 months ago 4 Members · 3 Replies -
David Bogie
July 13, 2005 at 2:49 pmThere are dozens of possibilities unfortunately, difficult to debug. You can search the forum for dropped frames and see if any of the many threads offer anything relevant. That might be faster than us suggesting lots of stuff you’ve already tried, doesn’t apply to your situation or might not understand. No way to know from here.
It’s usually a question of FW traffic, one silly or incorrect setting or a mechanical issue with the drive.
bogiesan
Lars
July 13, 2005 at 2:53 pmI have the same setup and the same problem. I also tried the “render only-mixdown” didn
Walter Biscardi
July 13, 2005 at 3:27 pmfirst off, what kind of footage are you trying to play?
Check Canvas is set to Fit To Window. that’s a big one that get’s a lot of people.
check that your sequence / capture settings match.
As bogey notes, there are dozens of reasons for this from FCP Settings to Hardware to User Error.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
