Activity › Forums › Apple Final Cut Pro Legacy › Dropping Edited 23.98 into SD Sequence for SD Mastering
  • Dropping Edited 23.98 into SD Sequence for SD Mastering
    Posted by Brad Dash on July 27, 2005 at 10:00 pm
    I dropped in my edited footage, DVCproHD, 23.98 PsF into an Uncompressed 10 bit Standard Def Sequence.
    I am operating on a dual 2.5 with FCP 4.5, with a Kona 2 card.
    2 things:
    The frame rate conversion seemed to happen automatically, leaving a barley acceptable jitteriness to the footage. Is there any way to adjust or further refine this step?
    And is there a way to decide what to do with this HD footage in respect to aspect ratio? It has defaulted to letterbox, without a seemingly obvious way to iterpred differentley; i.e. Pan&Scan/Edge Crop, or Anamorphic.
    THANK YOU TO ALL OF YOU IN ADVANCE. I am new to this workflow and have been away from Apple products in a professional editing environment since System 9. Glad to be back, but I need some help. When I become top dog final cut guy, I can’t wait to help spread the wealth.
    Hope to hear back from you all.
    Walter Biscardi replied 21 years, 2 months ago 2 Members · 3 Replies
  • Walter Biscardi
    July 28, 2005 at 3:09 am
    [AppleFreak] “I dropped in my edited footage, DVCproHD, 23.98 PsF into an Uncompressed 10 bit Standard Def Sequence.
    I am operating on a dual 2.5 with FCP 4.5, with a Kona 2 card.”
    Are you simply trying to downconvert this for an SD master? The Kona 2 will do this in real-time on output via your HD timelime. It’s incredibly clean with no need to render or re-set anything.
    Just use the Kona 2 Control Panel and you can set the Component output to SD-DownConvert and then you can decide whether to Letterbox, Crop or Pan and Scan.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Brad Dash
    July 28, 2005 at 1:17 pm
    So, I actually need to have the project layed into an SD timeline for mastering, I need to add some things into the letterboxed area.
  • Walter Biscardi
    July 28, 2005 at 1:25 pm
    [AppleFreak] “So, I actually need to have the project layed into an SD timeline for mastering, I need to add some things into the letterboxed area.”
    If you’re doing a straight downconvert, no you leave your timeline as an HD timeline and play it straight out. The Kona 2 will downconvert it on the way to your SD deck.
    If you’re wanting to add material to the letterboxed area, then yes, you’ll need to set up a 29.97 SD 8 or 10bit timeline and re-size the footage to however you want it to look. You’ll then have to render out the entire timeline before mastering.
