Activity Forums Adobe Premiere Pro Dropped Frame/Transitions on Export
  • Dropped Frame/Transitions on Export
    Posted by Brad Weiss on November 13, 2007 at 11:06 pm
    Hello fellow CCows,
    I’ve used this forum numerous time with great results, so i’m hoping you can help me with my latest conundrum.
    I’m working on a series of animatic stories (editing in Adobe Premiere Pro CS3) being used as a pitching tool for an upcoming feature. They are essentially a series of still images (created by a storyboard artist) some of which give the appearance of animation when played back to back.
    My problem is this: when i attempt to export some of these sequences the resulting video file (exporting to .MOV) doesn’t play the ‘animatic’ sequences (some of which are only a few frames) at all, but rather shows the images before and after it. This has also resulted in a timing issue, as all of the stories have music cut to specific transition points in them.
    Any idea what could be causing this dropped frames/ transition glitches? I need a fresh take on this.
    Your Truly,
    The Insane Raven (aka. Brad)
    Vince Becquiot replied 18 years, 10 months ago 2 Members · 1 Reply
  • Vince Becquiot
    November 13, 2007 at 11:18 pm
    What format are the original file encoded in ?
    Vince
