Activity › Forums › Apple Final Cut Pro Legacy › Dropped frames with fast raid in 6 but not 5.1.4
Posted by Simon Blackledge on July 10, 2007 at 8:21 amAnyone else getting dropped frames on capture with FCP6 where they never did with FCP 5.1.4?
We have a raid able to do 450MB/s and seemed fine in 5.1.4. Now on fcp6 and we get dropped frames after about 2>3 mins.
Also I could do 3 streams of 720P60 10bit layers in timline but now even 2 stremas reports slow disks in FCP6 ?
Anyone shed any light?
Cheers
P
Simon Blackledge replied 19 years, 2 months ago 3 Members · 9 Replies -
Jerry Hofmann
July 10, 2007 at 12:19 pmTry a clean install of the startup disk if you didn’t do that when you went to FCS 2.
Jerry
Simon Blackledge
July 11, 2007 at 7:55 amWere capturing from xbox360 at 720P 59.94 uncompressed 8bit.
MacPro
4gig
ati190010.4.10
Clean install of FCS2 then upgraded to latest versions, including BM drivers.HBA slot 4
BM HD Extreme slot 3
empty slot 2
ATI1900 slot 1Expansion slot utility option 2 selected
Raid is 8disk sata with highpoint card. AJA disk test rates at 450 MB/s when empty. 3.2TB (8x500gig @ raid5) Now have 1.6TB free and still tests at 360 MB/s
AJA graph does show spikes though :-/Everyone else fine running FCS2 then ?
Any ideas Walter?
thanks
Si -
Walter Biscardi
July 11, 2007 at 8:55 am[pennello] “Everyone else fine running FCS2 then ?
Any ideas Walter?”
I would look at the drivers of the storage array and your BMD card myself. Other than that I really don’t have any suggestions.
We have three FCS2 systems running perfectly fine over here, though we run all AJA products on our systems.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Simon Blackledge
July 11, 2007 at 10:12 amThanks Walter. I’m going to swap the BM and HBA around. Suggested by Highpoint.
Have you tried a Caldigit HDPRO ?
Cheers
Si
Walter Biscardi
July 12, 2007 at 12:07 am[pennello] ”
Have you tried a Caldigit HDPRO ?”Nope, won’t use their products anymore.
Simon Blackledge
July 12, 2007 at 7:09 pmHow come? :-/
what do you suggest for upto 2k read write on a macpro ?
Walter Biscardi
July 12, 2007 at 7:34 pm[pennello] “How come?”
Bad reliability issues here.
[pennello] “what do you suggest for upto 2k read write on a macpro ?”
Sonnett Fusion F800 (8bay), MaxxDigital ProAVIO (8bay), Ciprico, Facilis. We’re testing Dulce units right now, but I don’t think they’re fast enough for 2k. Uncompressed HD sure, but not 2K.
Simon Blackledge
July 12, 2007 at 8:21 pmThanks Walter. much appreciated. We have a proavio/enhance 8ML infiniband but I think the highpoint 2322 is giving us issues.
Thanks for the info.
s
Simon Blackledge
July 12, 2007 at 8:28 pmAlso intresting how Dulce don’t show the graph with the AJA test.. :-/
