Activity Forums Apple Final Cut Pro Legacy dropped frames warning
  • dropped frames warning
    Posted by Javier Quinones on September 8, 2010 at 2:00 pm
    hello, i keep getting a dropped frames warning when i add effects to a clip, i am using the mac osx
    processor- 2ghz intel core 2 duo
    memory- 2 gb 667 Mhz ddr2 sdram
    i am using a panasonic avccam HMC150. the files are Mts files, i use a program called cineform neoscene to convert the files to mov files
    Where do i go to change the following?
    the warning is telling me to turn off unlimited rt
    lower my compression data rate
    increase the speed of your system
    Shane Ross replied 16 years ago 2 Members · 1 Reply
