Activity Forums Apple Final Cut Pro Legacy Dropped frames SD firewire400
  • Dropped frames SD firewire400
    Posted by Jon Lewis on May 26, 2009 at 7:39 pm
    Hello all – this is my first post.
    I recently picked up final cut pro 6 and installed it on my mac. I quickly realized that I would need to upgrade my macbook if I wanted to stop getting the dreaded “dropped frames” warning every two seconds during playback. Since then…
    – I’ve upgraded my macbook’s RAM to 2 Gb – no, it’s not a pro 🙁 –
    – I have my media files stored on an external SATA hard drive (7200 rpm, 16 mb cache, firewire 400 connection to macbook)
    Even tho my scratch disks are set on the external hard drive, I am getting the same dropped frames warning (despite lowering my playback settings) just by slowing down my clip via time-remap to 80% and putting in a transition.
    I don’t know. Maybe I have the scratch disk set up wrong ? The footage isn’t HD or anything, it’s a 40 mb MPEG 4 video
    Any advice would be greatly appreciated. –jL
    Jon Lewis replied 17 years, 4 months ago 2 Members · 4 Replies
  • Shane Ross
    May 26, 2009 at 9:16 pm
    [Jon Lucas] “it’s a 40 mb MPEG 4 video”
    That’s your problem…MPEG-4 is not an editable codec. You need to convert to a format you find in the EASY SETUPS, like DV/NTSC.
    MPEG STREAMCLIP does this…and it’s free. GOOGLE!
    Shane
  • Shane Ross
    May 26, 2009 at 10:46 pm
    No. The amount of RAM is now good, and you should NEVER edit using USB. Not suited for video editing.
    Shane
  • Jon Lewis
    May 26, 2009 at 10:47 pm
    Awesome! I will try that tonight. I had read that some formats were too “codec-y” for final cut to work with, but i assumed mpeg4 was fine because its common and small. Good to know that is not the case. Thanks for the help !
    PS – does this mean that upgrading my RAM and hard drive (USB to firewire 400) was unnecessary ?
  • Jon Lewis
    May 27, 2009 at 9:53 pm
    Works great now! Thanks a lot
