Activity › Forums › Apple Final Cut Pro Legacy › Dropped Frames on SD capture
  • Dropped Frames on SD capture
    Posted by Paul Connolly on June 19, 2009 at 11:27 pm
    Hi there,
    New to the mac and FCP (been using Avid on a pc for the last no of years)
    I bought the following set up:
    Mac Pro – Two 3.0GHz Quad Core, 8GB Ram, NVIDIA GeForce 8800GT 512MB GDDR3, 320GB 7200-rpm Serial ATA 3Gb/s, Five USB ports, Two FireWire 400 ports and Two Firewire 800 ports; 1.5TB internal RAID
    Mac OS X 10.5.2; QT version 7.4.5; FCP 6.0.3
    “Getting Organized in Final Cut Pro” – Shane Ross (invaluable!!)
    My problem is that I am capturing footage from my DSR-11 deck (DVCAM originated from Sony DSR450) via the fw400 (and also tried the fw800) port on the front of the mac and I am getting dropped frames on capture.
    I have the capture scratch set to the 1.5TB internal raid
    The RAID is formatted as mac os extended (journalled) – I am going to switch journalling off – but from the various threads it should not make much difference – as this is DV footage.
    I have read through the numerous posts on dropped frames and and am wondering has anyone any suggestions on what is causing the dropped frames on capture?
    Many thanks.
    Paul.
    Paul Connolly replied 17 years, 2 months ago 2 Members · 4 Replies
  • Michael Gissing
    June 19, 2009 at 11:57 pm
    I would update both quicktime & FCP to the latest versions. That setup should never have issues with DV. I suspect the FCP quicktime combo as your hardware is well over spec.
    Most people moved quickly off the earlier and buggy version of vers 6 and there have been some quicktime versions that were for the iPhone and not helpful for FCP
  • Michael Gissing
    June 20, 2009 at 12:03 am
    Of course, the other thing you will find out about FCP is the trick of trashing preferences and repairing disk permissions when things behave badly. Searching this forum will describe in great details how to do this.
    There are a few excellent free utilities to help with this.
  • Paul Connolly
    June 20, 2009 at 6:55 am
    Thanks for the advice Michael,
    I will give these a try.
  • Paul Connolly
    July 6, 2009 at 7:56 am
    Hello again,
    I have updated the OS, FCP and QT to the latest versions.
    I have used disk warrior and “techtool deluxe” to check all my drives – and all show up as ok.
    However, I am still getting the dropped frames issue.
    I captured 3 clips x 20 minutes – and got a dropped frame on the third clip.
    Can anyone help?
    Paul.
