Activity › Forums › Apple Final Cut Pro Legacy › dropped frames on multicam 16 up
  • dropped frames on multicam 16 up
    Posted by L Isha on October 8, 2005 at 3:13 am
    Hello to all,
    I am working on a multicam project which was shot on DVCPro50/24P advanced in 16×9. I captured the footage at dv/dvcpro-NTSC to an internal 400 gig SATA drive to save space. I am using a Blackmagic Decklink via SDI. Once I complete the edit I will online to DVCPro50.
    4 cameras were used with 4 takes of each scene. I want to use the multicam feature to put up all 16 angles at once. When I use the multicam feature with 9 angles I am able to switch between angles with no problem. However when I switch to 16 angles I get dropped frames. What should I do to make the 16 up option play without dropping frames?
    My settings are as follows:
    Frame Rate: 720×480
    Vid Rate: 29.97
    Compressor: DV/DVCPro-NTSC
    Data Rate: 3.7 MB/sec.
    Aud. Rate: 48khz
    Aud Format: 24-bit integer
    Composite: Normal
    Pixel Aspect: NTSC-CCIR 601
    Anamorphic
    Field Dominance: Lower
    Dynamic RT is checked in the sequence
    Thanks so much!
    Lisha
    FCP 5
    10.4.2
    Dual 2.3 ghz G5
    5GB DDR SDRAM
    Blackmagic Decklink
    400 gig internal SATA drive
    Dan Riley replied 20 years, 12 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Riley
    October 8, 2005 at 4:23 am
    I offer the following as only from my perspective.
    Take if or leave it.
    If you have 4 cameras and four takes,
    that’s 4 multiclips, each with 4 cameras and a take.
    Yes?
    I edit multicam shows all the time (4 or 5 camera
    simultanious timecode studio shows) and that’s
    the way I make multiclips. Did it that way in AVID
    for years too. Why would you want to see all
    the takes running at the same time, with different
    audio and different timing and movements?
    Watch all four multiclip takes separately and pick one.
    If you don’t like one of the camera shots,
    go get another one from another take from another multiclip.
    Now, as for trying to get FCP to playback 16 streams
    in realtime from one drive…..what are you smoking?
    You need a RAID for that; I don’t care what the FCP
    marketing stuff says.
    Dan
  • L Isha
    October 8, 2005 at 4:34 am
    Hi Dan,
    Thanks! Actually the RAID is on order and due in next week (https://www.caeneng.com/products/raid_sata-i.shtml). So with the RAID I will be able to do 16 up?
    The shoot is a performance show. The talent performed to music tracks. Since each take was shot with the talent performing to the same music track I thought it would save time to put all the angles up at once. All 16 angles will be used to edit into one performance clip. I am open to suggestions on the best way to edit this. I have 12 performances to edit down. 12 performances — 4 cameras — 4 takes of each performance. In some instances the talent flubbed the song, so then I have partial takes of the song. AND I am on a deadline! LOL!
    Thanks so much!
    Lisha
  • Dan Riley
    October 8, 2005 at 6:19 am
    Although you are doing something different than me, in the sense that
    it’s the same audio track for each take, I still would make multiclips
    of each take of 4 cameras. You sit and you watch them and memorize
    the good and the bad of each. Then you watch the next one.
    After you watch all four takes, drag your favorite one, or at least
    the one that starts out the best, to the timeline and edit to that one.
    You can always load the other takes in the viewer and find
    better shots, but you need to lay down a starting point.
    For me, looking at all the takes at once, in 16 very small screens,
    doesn’t seem useful. But that’s just me.
    If it works for you, who the heck am I to tell you to change.
    As for the RAID playing back all 16 streams, how many drives
    are you getting? What SATA PCI card are you getting?
    It’s tuff to say if it will work or not. There is the issue of
    your CPU. Is it a dual machine or single?
    FCP doesn’t run too well for RT multistream playback
    unless it’s one of the newer ones. I use a dual 2.5 gig.
    But I only run 4up for multicam. No trouble most of the time,
    but I occationally get dropped frames. But it’s only
    while all the screens are ganged, not for just the
    sequence playback. I have a 4 drive SATA RAID
    using the Sonnet 4+4 card.
    My issue right now is since I’ve been using FCP5.0.2
    I’ve been getting random crashes of FCP. This almost
    never happed with 4.5, and I’m pissed off about it.
    My system didn’t change, just the OS (tiger) and FCP to 5.
    It’s not ‘pro’ anymore in my book right now. The lost
    productivity from all the restarts and resetting and
    redoing lost edits is making a move back to the AVID
    a more financially viable option. The Media Composer
    costs much more upfront but it is rock solid and you get
    your work done and out the door much faster.
    Dan
  • Bouncing Account needs new email address
    October 8, 2005 at 11:58 am
    [Danrnw] “The Media Composer
    your work done and out the door much faster.”
    Deja Vu!
    I remember the same things being said about ON-LINE 1″ VPR and BetaCam edit suites vs. the (then) new Avid MC systems.
    Only THEN it was, “It may cost us nearly a MILLION DOLLARS to build an on-line suite, but that cheap ($80,000) Avid keeps crashing and we need to get the work done!”
    Budgets, gear (and Perspectives) sure change as time goes by.
    (Happy with FCP now, and know it will only get better and cheaper.)
  • L Isha
    October 8, 2005 at 1:18 pm
    Thanks Dan!
    I am swaying towards using 4up and or 8up due to the amount of time I have to cut this. The first two takes were done with 2 stationary cameras, the 3 rd take concentrated on a jib shot with the other cameras running and the 4th shot concentrated on a steadi cam shot with the other cameras rolling. Are you suggesting build in the timeline using one take at a time? I used to do that when I did music videos on Avid. 🙂 You bring up a good point about the best way to edit this. Time to start a new post! LOL!
    My system is a G5, dual 2.3 with an additional 5 gigs of ram.
    I am getting the ATTO card…
    https://www.attotech.com/ultra4s.html
    “The ATTO ExpressPCI UL4S offers the latest in SCSI storage connectivity, delivering the ultimate data-delivery performance of up to 320 MB/sec. The UL4S which features the new PCI-X bus interface and incorporates improved SCSI standards, is ideal for delivering data to the most demanding Enterprise server and high-end workstation environments. Enabled with ATTO’s exclusive VpathTM Technology, the UL4S offers users the flexibility of connecting high-speed Ultra320 devices externally and slower legacy devices internally, or vice versa, without sacrificing the performance of the high-speed device. This allows users to take full advantage of Ultra320 and legacy speeds simultaneously.”
    And a CAEN RAID
    http://www.caeneng.com
    Overview
    Fibrenetix FX 606-U4 combines Ultra320 host connection with SATA drive interface to offer blistering performance at unbeatable price. The FX 606-U4 is totally OS independent and offers true plug and play connectivity to any Windows or Macintosh environment with no software or drivers required. It provides enhanced features and capabilities making it very easy to use with minimal technical maintenance.
    The stylish, portable 5-bay enclosure makes the FX 606U4 an ideal back-up device and provides an impressive 2 Terabyte storage capacity. The FX 606U4 is a truly versatile RAID system, perfect for any end user environment where high performance and problem-free mass storage is a requirement.
    Features
    Hardware RAID controller with Intel 80321 400MHz 64-bit RISC processor
    Ultra320 SCSI host interface
    5x SATA drive channels
    128MB onboard cache memory with ECC protection
    RAID levels 0,1,0+1, 3, 5 and JBOD
    OS Independent and Transparent
    Supports multiple RAID sets
    Array roaming – seamless movement of HDDs without any loss of configuration or data
    Online stripe size migration
    Online capacity expansion and RAID level migration – add new drives to an existing array and change RAID level simultaneously
    Automatic and transparent hot spare rebuild
    Hot-Swappable Drives
    Instant availability and background initialization
    Automatic drive insertion / removal detection and rebuild
    NVRAM for transaction log
    Write-through and Write-back cache support
    WEB based RAID management via HTTP Proxy
    Firmware embedded manager via LCD control panel or RS-232 port
    Specifications
    RAID Architecture Daytona RAID Engine
    RAID Controller Intel 80321 64-bit RISC 400 MHz Microprocessor
    Max. Supported # Drives 5x SATA HDDs
    Supported RAID Levels JBOD, 0, 1, 0+1, 3 & 5
    Memory Bus 266 MHz PC-2100 Memory
    Memory Type Industry Standard DDR ECC SDRAM
    Memory 128 MB Standard
    Host Bus Interface Ultra-320 SCSI
    Disk Bus Interface 1.5-Gbit PHY Serial-ATA
    Disk Bus Channels 5 Independent Channels
    Host Independent & Transparent Yes
    Operating Systems Supported
    Windows Server 2003, Windows 2000, MSCS (Microsoft Cluster Server) Windows NT, Windows XP-Pro, Sun-Solaris, linux, true64 Unix, HP-UX, IBM-AIX, SGI-IRIX, MAC-OS, Free BSD, Novell, plus any standard SCSI interface.
    HDD supported max. Capacity 500 GB
    Maximum Subsystem Capacity 2.5 TB in RAID-0 & JBOD, 2 TB in RAID-5
    Drive Temperature Sensors Yes, One per Drive-Slot
    Redundant Components Hard Disk Drives
    Management RS-232, Web-browser and SNMP
    Alerts Audible alarm, LEDs, RS-232, Web-browser, Email and SNMP traps
    Power Requirements 110/240V, 47/63 Hz autoswitching (+/-10%)
    Power Supply Capacity 1x 150W PSU
    Operating Temperature 5
  • Dan Riley
    October 8, 2005 at 3:28 pm
    – Of track here for a second, but I must respond to a previous post.
    Matt,
    I’m the one who used to say all that about tape versus AVID
    in 1991. I’m one of the first producers here in Seattle that moved
    almost all his show production to AVID offline at that time,
    then onlined from the EDL on One Inch or D-2 at the time.
    I’m one of the first producers here to use FCP in 2000, version 1.25,
    to do the same thing. My online friends were saying it’s junk.
    We’ll in some ways it was at the time, but it made me more
    productive and I knew it would improve. I was the first of my
    friends to move to OSX, etc. etc.
    You are way behind the curve making your arguments.
    This is different. This is a company, Apple, who claims
    to sell a product that is Pro. It is not. It is a good product
    but Pro is something special. This is just a marketing term
    to Apple. It means nothing else to them, and FCP5 + .02,
    shows Apple did not do nearly enough testing of the software
    before releasing it. My problems aside, just read any forums
    you want and see for yourself. And I pity you if you have to
    do an uprez with FCP. What a sham. Media Management is for crap.
    This software was designed to do DV all the way through.
    Apple has not fixed the basic plumbing necessary to allow it
    to smoothly edit in one format and then move the project
    to another.
    As I’ve said in my other forum responses, I love my Mac and
    most of the time I love FCP. But right now I’m pissed off.
    They are using the user base as their beta testers.
    Apple rushed this release out the door too soon.
    This is not “pro” application behavior.
    Dan
  • Dan Riley
    October 8, 2005 at 3:39 pm
    L isha,
    About your RAID setup, I’ve never heard of them.
    I’ll read their info. But SCSI controller with SATA drives?
    I’ve not followed this developement area.
    You may be blazing a trail here and I’m not so sure
    that’s a good idea. But like I said, I’ll need to read up on it.
    As for your editing style, everyone has their own way.
    Mine is probably no better a style, just different.
    But after thinking about your particular situation,
    with the same audio track and 4 different takes,
    I think I see why you might want to try the 16 screens.
    But equipment doesn’t always allow us to do what our heads
    tell us will work out. And having FCP display 16 at a time
    is asking alot, even though Apple says it can do it.
    Using the 4 camera, 4 multiclip approach,
    it seems to me however, that if you started with a take
    you liked, picked the shots you liked, then went back
    and decided which ones could be better, then went back
    and looked at your other multiclips of the other takes,
    found a better shot and used it, that would do it. You’d be done.
    Dan
    October 8, 2005 at 4:41 pm
    [Danrnw] “You are way behind the curve making your arguments.”
    Sorry, I had no idea I was talking to the editor who discovered Avid.
    My arguments will never be as up-to-date as yours.
  • Dan Riley
    October 8, 2005 at 5:19 pm
    You’re a fun guy.
    If that’s what you care to read into what I said,
    that’s too bad.
    Dan
