Activity Forums Apple Final Cut Pro Legacy Dropped Frames on Mountain Lion
  • Dropped Frames on Mountain Lion
    Posted by Bernardo Brik on September 11, 2012 at 1:28 pm
    I installed Mountain Lion on my Mac Pro 8 core. Everything seems to work fine, but FCP 7.0.3. I get dropped frames after a few seconds of playback. This system works fine with Lion. Any ideas?
    My setup is:
    Mac Pro 5,1 8 core
    15gb RAM
    System on 120gb SSD
    Data on 12tb internal RAID
    Nvidia GTX 570 (non EFI)
    DeckLink HD Extreme 3D+
    Thanks in advance,
    Bernardo
    Thomas Berglund replied 12 years, 11 months ago 14 Members · 32 Replies
  • 32 Replies
  • Borko Grujic
    September 14, 2012 at 7:20 am
    I have the same problem (very similar setup). Big problem when recording to tape!
    Let me know if you figure it out.
    I also have flicker when playing mov files in quicktime on all mountain lion macs
    B.
  • Bernardo Brik
    October 9, 2012 at 12:52 pm
    Hi Borko, I havent figured it out yet. I think it has to be a problem with Mountain Lion’s nvidia driver. But I didn’t swap the GTX for my ATI for testing yet.
    Here FCP stops playing around the first 5 seconds of play. If it goes beyond that limit, it can play the entire program.
    Let me know if you find something.
    Bernardo
  • Joe Langenfeld
    October 14, 2012 at 5:48 pm
    I have the same problem, dropped frames in FCP7 with Mountain Lion on a Mac Pro 8 core and a Macbook air, even with DV footage. Booting in Lion with same project plays perfectly, no dropped frames. Let’s hope update fixes…
  • Brandon Kraemer
    October 14, 2012 at 10:29 pm
    I am having this same issue. Just changed my system from a Kona 3 to the BMD Decklink 3D+ card and upgraded to Mountain Lion and now it’s drop frame city.
    I was running FCP 7 for about 4 days in Mountain Lion prior to swapping cards with out drop frames so it looks like it’s the Decklink.
  • Brandon Kraemer
    October 15, 2012 at 6:05 pm
    What PCI slot are people’s Decklink cards installed in? Mine is in slot4, only other option for me is slot3. Haven’t tested swapping yet.
  • Brandon Kraemer
    October 17, 2012 at 5:59 pm
    Has anyone found a solution to this? I recently tried isolating my NVidia cards from the system and disabled the NVidia drivers with no luck. The only thing that solved it was to disable the driver for the Blackmagic DeckLink, but then I have no video output. This wasn’t an issue under Mountain Lion with my Kona 3 card, but that card is incompatible with Resolve.
  • Bernardo Brik
    October 17, 2012 at 11:30 pm
    Mine is in slot 3. Are you positive that the issue is with the DeckLink? I thought it was nVidia related.
  • Bernardo Brik
    October 18, 2012 at 12:13 am
    Hi, I think the issue is with black magic audio. I changed FCP audio outputs to use internal line out and it looks like the problem is solved!
  • Brandon Kraemer
    October 18, 2012 at 12:46 pm
    Yes, the audio out on the Blackmagic card does seem to contribute to the problem. However, problem just changes, I get video out with out dropped frames but now my audio is out of sync!
  • Brandon Kraemer
    It’s definitely DeckLink. I isolated everything NVidia out of my system and the problem persisted.
Page 1 of 4
