Activity Forums Apple Final Cut Pro Legacy Dropped frames in HDV Capture
  • Dropped frames in HDV Capture
    Posted by Martin Gaxiola on June 30, 2007 at 12:57 am
    I have not been able to find a prior posting that dealt with this situation. So here is my question:
    I am trying to capture HDV footage via firewire from a Sony HVR-1500 deck into Final Cut Pro 2. Project settings are HDV-1080i60.
    Machine specs:
    Mac Pro
    3.0 Dual Quad Xeon
    8GB RAM
    Scratch disk (2nd internal SATA drive = 750GB)
    Mac OS 10.4.10
    I have no problems capturing the footage via the Capture Now feature (I am capturing the whole tape and not just clips). However FCP is dropping frames in capture resulting in multiple video files per tape (I get no error messages of dropped frames and the capture process is never interrupted). I made sure that I turned off the “Create new clip on start/stop” because I want just one file per capture. Any thoughts as to why this is happening? Any fixes? Should I try capturing in a different codec during capture to avoid this problem? Thanks! 🙂
    Mdneely replied 19 years, 2 months ago 3 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    June 30, 2007 at 7:16 am
    douse your tape have timecode breaks
  • Martin Gaxiola
    June 30, 2007 at 12:55 pm
    Thanks for the tip. I just figured out that I had to turn off the Abort when there is a break in timecode in the user preferences. That was causing FCP to create a new clip at each timecode break. My bad….
  • Martin Gaxiola
    June 30, 2007 at 5:09 pm
    Spoke too soon. I am still having the same problem.
    I do have timecode breaks, but not in the middle of the footage where the dropped frames are happening. The footage is of a dance concert and the recording is continuous (so there should not be any intended breaks in the timecode).
  • Mdneely
    July 2, 2007 at 3:49 pm
    i too have had this problem capturing via firewire w/a canon xh-g1 HDV 24f to a glyph 1TB RAID.
