Activity Forums Apple Final Cut Pro Legacy Dropped frames in FCP 7
  • Shane Ross
    September 11, 2010 at 11:30 pm
    [Anthony Dias] “- Digidesign MBox 2 Pro (which is on it’s own FireWire PCI card because it used to cause my audio to stop working)”
    Disconnect this… now do you get dropped frames? Uninstall the drivers…now?
    I had a system where the producers wanted a station to be the online station AND ProTools station (audio engineer worked on the system at night). When I installed the Digitdesign MBOX Pro, my system didn’t function well at all. Didn’t like it. So, I uninstalled it. Installed a second hard drive, installed a fresh OS on that, then the ProTools and MBOX drivers on that, and booted to that drive when going to a ProTools mix. I even unplugged the unit from my system when I worked.
    That might be your issue…incompatible hardware/software.
    [Anthony Dias] “- ColorMunki (definitely has cause some headaches as well with Motion showing blank canvases)”
    This too. Disconnect…then uninstall. See if things persist.
    Shane
Page 4 of 4
