Activity Forums Apple Final Cut Pro Legacy Dropped frames during playback.
  • Dropped frames during playback.
    Posted by Paul Kavadias on June 22, 2005 at 9:28 pm
    In FCP5 (this also occured in fcp hd), whenever I try to play the video out through the firewire port, I get dropped frames during playback. This is a problem which popped up just recently. We are using a dual 1.8 g5 (the first gen w/ the pci-x) with 1.5 gbs of ram. We also have an ads tech pyro box (looking to upgrade this soon) for output.
    Any suggestions on how to eliminate this problem would be greatly appreciated (I’ve tried all the suggestions which I found on the net – not sure exactly where this link was from.)
    Paul
    Kevin Monahan replied 21 years, 3 months ago 2 Members · 1 Reply
  • Kevin Monahan
    June 22, 2005 at 10:39 pm
    I’d get a PCI card to make a new bus to separate the firewire drive and the camcorder. Another solution would be to avoid firewire drives and use internal SATA drives only. A third solution is to export your sequence as a single QT ref. movie, then reimport it an play that instead.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
