Activity Forums Apple Final Cut Pro Legacy Dropped Frames During Capture on X-RAID using FCP HD
  • Dropped Frames During Capture on X-RAID using FCP HD
    Posted by Scott B. on March 14, 2006 at 12:55 am
    I am experienceing dropped frames (error message in FCP states “Time Code Break”) during capture. I’m using a G5 2.0 and digitizing from a Sony HVR-M10U MDV deck to a new 3.5 TB X-RAID in RAID 5 without a server. I’ve read on the forum all about the different settings to avoid dropped frames and have tried them all (changed setting for NTSC, NTSC 23.9 etc without any luck). The footage was shot at 24p at 2:3 in non drop frame mode on an XL2.
    For a bit of history on the computer, I just recently installed the RAID to capture media and started experiencing dropped frames on capture. I have tested the same footage capturing on a G4 to a LeCie drive and it doesn’t have any problem so I know it is not a problem with the footage and may be the RAID. I have tried to change the jounaling setting in Disk Utilities on the RAID, but the journaling “enabling” button is grayed out and the RAID is set to “Mac OS Extended (journaling).” Is this the cause of the problem, and how can it be fixed?
    A second problem with the RAID is a failure to connect to RAID Admin through the Ethernet cable (CAT 5). It connected after the install and then about a week later it stopped after I opened the Admin and it wouldn’t take the default passwords. I am perplexed and confusethed. Any ideas? I appreciate any input you might have.
    Leon Johnson replied 20 years, 5 months ago 4 Members · 4 Replies
  • Jeffrey Burns
    March 14, 2006 at 1:51 am
    The xserve G5 OSX server requires its own partition for the metadata. This means you need to dedicate half of a xserve RAID rack to do this. I just purchased a second xServe RAID in order to do this. I have 6 terabytes of storage for video and 500 meg for metadata. This seems to have fixed the problem. I assume you using xsan clients and have a OSX Server.
  • Tony! Hulette
    March 14, 2006 at 9:37 am
    Make sure in your performance settings that “Use Controller Write Cache” is on (make your you have the RAID connected to an uninterruptible power supply) and the “Use Drive Write Cache” is checked. Make sure that the “Allow Host Cache Flushing” and “Use Steady Streaming Mode” is left unchecked. I use the 8 stripes option.
    You must format the RAID as Mac OS Extended (no journaling).
    Make sure your RAID and the Fibre channel card has the latest firmware (backup before updating). Make sure no other card is plugged into the same PCI bus as your Fibre channel card.
    If you’re capturing through your Mac’s Firewire port, make sure no other Firewire devices are connected while capturing. If you using a capture card/device, check with the manufacturer for suggestions.
    Triple check your FCP settings and make sure the video/audio is not going to the startup drive and that all your capture settings are correct. Of course, make sure the Canvas and Viewer is set to “Fit to Window.”
    Make sure the RAID is not anywhere close to full.
    Trash your FCP prefs and caches.
    Turn off any Virus software (or anything running that doesn’t need to be).
    Set your Energy Saver preferences to never for “Put your computer to sleep” and under options change your “Processor Performance” to “Highest.” (these probably won’t fix your problem, but you should do them anyway).
    If nothing else seems to work. Suspect 3rd party memory. Remove it all leaving only the stock Apple memory and see if the problem goes away.
    That’s all I have off the top of my head right now, but there’s probably a few doesn’t more possible causes.
    Good Luck,
    Tony!
    P.S. You can reset the controllers on your RAID and that will reset the default passwords. Here’s how: https://searchdocs.info.apple.com/article.html?artnum=86367&coll=cp
  • Scott B.
    March 18, 2006 at 1:00 am
    I found the solution to the “dropped frames” during capture issue I posted above. There is an Apple article, ID # 302780 “Xserve RAID:Optimizing video capture rates,” that solved the problem. In RAID Admin deselect the “Allow Host Flushing” button found in the Admin settings under “Use Controller Write Cache.” Do this every time the RAID is restarted. This solved the problem. ALthough I changed the settings on the RAID from Extended Jounaling to just Jounaling (which I found can be done only through Terminal in Applications by entering: “Diskutil disableJournal /volumes/RAID”)-mind the spaces!). By just disabling Journaling, the capture problem remained. Only after I deselected “allow Host Flushing” was I able to capture without dropped frames.
    Thanks for your help.
  • Leon Johnson
    March 30, 2006 at 8:16 am
    Just purchased a Lacie F800 1 TB RAID system for my Mac G5 1.8 Dual with 2.5 GB RAM. I did the required formatting directions out of the LACIE box, and connected it via firewire 800 to the MAC G5. The disk appeared on the desktop – no problems. I captured a few clips using Final Cut Pro 5, but then FCP started to drop frames.
    I found this thread, and thought I needed to download Xserve, and RAID Admin 1.5. I can’t, however, get the RAID drive to appear in the RAID Admin. I click Add System + button, but I can’t figure out how to get the RAID Admin to recognize the RAID that is on my desktop so I can follow the rest of the set up directions as described here: https://docs.info.apple.com/article.html?artnum=302780
    Thanks anyone who is able to help.
    Leon
