Activity Forums Apple Final Cut Pro Legacy Dropped Frames During Capture
  • Dropped Frames During Capture
    Posted by Rj Thomas on March 23, 2007 at 11:02 pm
    I’ve spent a bunch of time now going over every post in this archive and can’t find the answer.
    I capture from a Panasonic DVX100 to a G5 dual 1.8 (yeah, I know – not the greatest but it works for me (well, usually))
    I capture over FW. Cam is connected to the front port on the Mac – the drives to a FW 800 card on the back of the Mac. My drives have plenty of room and I’ve tried switching drives.
    I’ve been doing this for a few years – never had a problem.
    Today I get dropped frames.
    In trying to troubleshoot this, I put back in a tape I had already successfully captured and it gave me the same damn dropped frames thing.
    I tried trashing my prefs – didn’t help.
    I tried turning off Abort Capture on Dropped frames and it still captures the footage but the footage has dropped frames in it. (Basically where the frame is dropped I get a freeze frame for 1/2 a second or so, then it jumps back to where it should be.)
    The only thing I changed on this computer recently was I added more RAM. I put in two Patriot 1 GB chips.
    Can anyone help?
    RJ Thomas
    Rj Thomas replied 19 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Rj Thomas
    March 23, 2007 at 11:15 pm
    Oh yeah – and adding insult to injury – it turns out that everything I capture with the “abort on dropped frames” turned off is out of sync after the dropped frames.
    RJ
  • William Kelly
    March 24, 2007 at 12:45 am
    Did you recently do the 10.4.9 update? I was recently experiencing very similar issues on my usually rock solid Dual G5. It turned out to be the update, unfortunatley to fix the problem required a complete wipe and re-install.
  • Debe
    March 24, 2007 at 2:27 pm
    Also, did you try taking out the new RAM and seeing if the problem clears up?
    debe
  • Rj Thomas
    March 25, 2007 at 12:34 am
    I did recently upgrade to 10.4.9 – I wonder. Hmmm.
    Also – no I have not taken out the RAM yet.
    Drat.
  • Tom Wolsky
    March 25, 2007 at 12:41 am
    The is an Apple doc about capture problems in FCP and FCE in versions prior to FCP5 and FCE3.5.
    https://docs.info.apple.com/article.html?artnum=305284
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Rj Thomas
    March 25, 2007 at 3:52 pm
    Thanks – that appears to be it. I’m running 4.5. I guess it’s time to upgrade.
  • Tom Wolsky
    March 25, 2007 at 4:13 pm
    Unfortunately you’ve missed the Apple crossgrade deal which expired about a week ago. If you can you’re probably best off waiting until April 15th to see whatever NAB announcement Apple will be making.
    All the best,
    Tom
  • Rj Thomas
    March 26, 2007 at 6:27 pm
    I think I can wait. I’ll just archive and reinstall and then see what comes up.
