Activity › Forums › VEGAS Pro › Dropped Frames During Capture
  • Dropped Frames During Capture
    Posted by Corey Whitley on June 7, 2008 at 2:18 pm
    I am using Sony Vegas 8 on a Quad Core PC and capturing via Blackmagic Design DeckLink. I am batch capturing from a Sony Beta SP Deck and am getting dropped frame counts on every capture.
    The longer I let the capture go the more frames are dropped.
    I decided to capture video from a cannon handy cam to see if there was a difference, and I didn’t drop a single frame, upon multiple stops and starts.
    Does anyone know of settings I may need to adjust in Vegas or with the deck itself. Thanks
    Corey Whitley
    Corey Whitley replied 18 years, 3 months ago 1 Member · 1 Reply
  • Corey Whitley
    June 10, 2008 at 5:17 pm
    So I bumped up the
    “Maximum RAM buffer size:” to 100%
    and the “Capture Latency (frames):” to 30
    and I am no longer dropping frames from my SDI capture.
    But for some reason it will not capture any longer than abut 2:30. I try to set in and out points of longer length and I can’t capture a whole tape. Any help would be huge.
    Thanks.
    Corey Whitley
