Activity Forums Apple Final Cut Pro Legacy Dropped Frames are Killing me
  • Dropped Frames are Killing me
    Posted by Bill Reber on May 12, 2010 at 1:40 am
    I’ve had dropped frames before, but today hit a new low when I got the dropped frames error while simply trying to play an audio track.
    I can’t seem to get more than 5 seconds of playback lately without the dreaded error window.
    This is FCP 7 installed just weeks ago on a brand new 8 Core Mac Pro. 2 x 2.26 Ghz Quad-Core. 12 GB 1066 MHz DDR3 RAM. Scratch is set to a clean 1 TB internal Media Drive.
    This is a super machine, and this should not be happening.
    Sequence matches footage, safe RT, lowered playback to medium, playback frame rate is at half.
    I’ve done everything I know to do, and yet it persists.
    Feel like there are either some advanced techniques or some very basic ones that I am missing.
    Thanks in advance for any ideas.
    Javier Quinones replied 16 years ago 6 Members · 9 Replies
  • 9 Replies
  • Robb Harriss
    May 12, 2010 at 3:20 am
    change safe to unlimited
    Non-linear: all the time and nothing but.
  • Zane Barker
    May 12, 2010 at 5:14 am
    What format is your footage?
    How is your media drive attached?
    Hindsight is always 1080p
  • Bill Reber
    May 12, 2010 at 6:07 am
    Funny.
    Error arrives while working with all sorts of footage types (in different projects), but in this case footage is HD 1080p.
    Media drives are internal, attached in the factory buses.
  • Zane Barker
    May 12, 2010 at 3:35 pm
    1080p does not tell us much. What format is it? Ie HDV, AIC, PronRes, Pro Res HQ, DVC Pro HD, Uncompresses.
  • Bill Reber
    May 12, 2010 at 4:42 pm
    Sorry about that it’s not 1080p,
    Footage is actually DVCPRO HD (720p60), Linear PCM, Timecode
    Not sure about compression. Was shot on HVX200 L&T’d to QuickTimes.
  • Michael Allen
    May 13, 2010 at 3:40 pm
    Wow, I am very suprised that the first question asked to you was not…… wait for it…….. Did you do a clean install when you updated your system?
  • Peter Sasowsky
    May 19, 2010 at 4:25 am
    Well folks, I am getting the same problem and using DV footage. Something is up and it’s stopped me in my tracks.
  • Peter Sasowsky
    May 19, 2010 at 4:44 am
    I think I solved it. Run software update. Mine needed Qtime, ProKit and security updates. I have a feeling that the ProKit update was the issue.
  • Javier Quinones
    September 19, 2010 at 8:29 pm
    dropped frames warning
    mac osx 10.6.3
    processor 2ghz intel core 2 duo
    memory 2 GB 667 MHz DDR2 SDRAM
    I am using panasonic hmc 150
    i put my sd card in a belkin adapter that you buy at the mac store
    how do i lower my compression data rate?
    how do i increase the speed of my system or disk drives?
