Activity Forums VEGAS Pro dropped frames
  • dropped frames
    Posted by Kevin Mccarthy on March 14, 2007 at 9:26 pm
    I have a new computer, Dell GX270 2.4 Ghz, 1 gig extended ram nvida 3dforce MX400 dual head video card, Audigy sound card with Vegas 7. Everything has the lastest updates, drivers etc. No IRQ conflicts;. I’ve checked that DMA is enabled. I’ve tried different decks and camera as a source. different cables. I’ve run vid cap as a stand alone program. I still get 162 dropped frames in a 15 sec capture. at 17.4FPS. I’ve tried capturing to 3 different drives; an internal seperate drive from my C drive, a firewire 400 and a firewire 800 same results.
    Now here is the fun part. I installed the Ulead Studio 8 lite that came with the card and it captures video perfectly. Vegas will then play the video with no problems.
    Any suggestions?
    Kevin Mccarthy replied 19 years, 5 months ago 2 Members · 5 Replies
  • Gary Kleiner
    March 14, 2007 at 10:29 pm
    See if it helps to reduce the video window size during capture.
    Where is the 17.4 fps coming from?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Kevin Mccarthy
    March 15, 2007 at 2:30 pm
    Gary, thanks for the response. the 17.4fps comes from the message after I stop the capture. it also shows a data rate of 1.99MB/sec.
    Are you talking about the window size in preview? If so, I had it on “auto” and tried reducing preview to half. That made no difference at all same problem, same rate etc.
  • Gary Kleiner
    March 15, 2007 at 2:59 pm
    [Kevin McCarthy] “Are you talking about the window size in preview?”
    The video window in the Capture application during capture.
    Gary Kleiner
  • Kevin Mccarthy
    March 16, 2007 at 3:44 pm
    Changing the size of the window does nothing to help.
    Is there a pre-capture buffer setting in capture that could be enlarged? I’ve had audio programs that that has helped in the past
  • Kevin Mccarthy
    March 16, 2007 at 4:50 pm
    An update, I tried un-checking base DV resolution decoding by preview window size. That had no effect. I reset it back to being checked
