Activity Forums Apple Final Cut Pro Legacy Dropped Frames
  • Posted by Gordon Gurley on June 27, 2007 at 6:34 pm
    Ughh. I know this has been covered here a million times, but I’ve never seen a good answer to my problems.
    Setup:
    XSAN 1.4/XRAID 14 drives
    G5 Dual 2.3 10.4.9 / 2 Gigs RAM / Kona LH 3.4 drivers / FCP 5.1.4 / QT 7.1.5
    MacPro Dual 3Gig 10.4.9 / 4 Gigs RAM / Kona LHe 3.4 drivers / 5.1.4 / 7.1.6
    So I get a lot of failed PTT/ETT’s on the G5 system above, usually with DV timelines. I just had a show that failed PTT 5 times in a row. I then PTT’d the show from the MacPro with no problems. I can understand that the Macpro is a more powerful machine, but I think a G5 should be able to handle DV without dropping frames.
    The G5 also drops fames in capture, especially with uncompressed SD.
    Where’s my Avid? I miss my Digital Cut.
    Gordon Gurley replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
