Activity Forums Apple Final Cut Pro Legacy Dropped Frames
  • Posted by Arturo Celleri on February 21, 2007 at 1:07 am
    I have captured video that plays back clean on my camcorder but when I capture it in FCP, I keep getting an error that reads:
    Dropped frames were detected during the last capture attempt.
    Is there anything I can do to prevent this from happening?
    Arturo
    Gary Adcock replied 19 years, 2 months ago 4 Members · 3 Replies
  • Eric Peterson
    February 21, 2007 at 1:34 am
    Need more info. Computer info. Capture card info. What are you storing your footage on?
  • Miklos Philips
    February 21, 2007 at 1:35 am
    There may be a choke on your system somewhere. Do not compare what plays back on your camcorder (off tape) to trying to capture in FCP, because it doesn’t even make sense. Capturing in FCP depends on your system’s speed, RAM size, hard drive speed, did I mention speed? It’s most likely your system is not fast enough to capture the digital video stream coming off your tape that you’re trying to capture. What’s more, whenever asking such a question, you will get more responses if you describe your issue with more detail including your system and FCP and Quicktime versions (at least.) Your question is too broad.
    Point Zero Pictures
    <https://www.pointzeropictures.com>
  • Gary Adcock
    February 21, 2007 at 2:12 am
    [Pachaunida] “Dropped frames were detected during the last capture attempt.
    Is there anything I can do to prevent this from happening?”
    faster storage devices , don’t capture to your system drive, only one thing on the FW bus
    to start.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
