Activity › Forums › Apple Final Cut Pro Legacy › Dropped Frame Warnings, MyBook External Hard Drive
  • Dropped Frame Warnings, MyBook External Hard Drive
    Posted by Vincent Strader on July 18, 2011 at 6:39 pm
    1920 x 1080 60i footage from SD 32 GB card (eFilm Pro SD/HC Class C6 Delkin Device)
    Editing off a “My Book Studio Edition II” Western Digital Hard Drive, 4 TBs.
    3.07 TBs available
    Had the Drop Frame messages. Closed all open sequences and still get the message.
    Transfered all my project files to my main media drive to give that a try.
    Worked well for about 30 minutes, then started to give me the Drop Frame messages again.
    Can SD cards get dropped frame issues on them after a while?
    Just in case, here are all the specs for the drive I’m using below (but I just recalled last night I transfered all the footage and projects to my main drive so the WD shouldn’t be an issue).
    My Book Studio Edition II 4 TB Hard Drives ( WDH2Q40000)
    Product Overview (PDF)
    Performance Specifications
    Serial Transfer Rate
    FireWire 800
    Serial Bus Transfer Rate (1394b) 800 Mb/s (Max)
    eSATA
    Serial Bus Transfer Rate (eSATA) 3 Gb/s (Max)
    FireWire 400
    Serial Bus Transfer Rate (1394a) 400 Mb/s (Max)
    USB 2.0
    Serial Bus Transfer Rate (USB 2.0) 480 Mb/s (Max)
    Physical Specifications
    Capacity 4 TB
    Interface Quad Interface
    Physical Dimensions
    English
    Height 6.54 Inches
    Depth 6.06 Inches
    Width 3.87 Inches
    Weight 5.2 Pounds
    Metric
    Height 166 mm
    Depth 154 mm
    Width 98.0 mm
    Weight 2.63 kg
    Environmental Specifications
    Temperature (English)
    Operating 41° F to 95° F
    Non-operating -4° F to 149° F
    Temperature (Metric)
    Operating 5° C to 35° C
    Non-operating -20° C to 65° C
    Electrical Specifications
    Current Requirements
    Power Dissipation
    AC Input Voltage 100-240 VAC
    AC Input Frequency 47-63 Hz
    As used for storage capacity, one megabyte (MB) = one million bytes, one gigabyte (GB) = one billion bytes, and one terabyte (TB) = one trillion bytes. Total accessible capacity varies depending on operating environment. As used for buffer or cache, one megabyte (MB) = 1,048,576 bytes. As used for transfer rate or interface, megabyte per second (MB/s) = one million bytes per second, megabit per second (Mb/s) = one million bits per second, and gigabit per second (Gb/s) = one billion bits per second.
    Vinnie
    24, LOST, Prison Break, FRINGE, Supernatural, DEXTER, Breaking Bad, CHUCK, Flash Forward, HEROES…even SMALLVILLE in the latter seasons.. they’ve all ruined my movie going experience by being better than so many movies out today.
    Everest Mokaeff replied 15 years, 2 months ago 3 Members · 2 Replies
  • Matt Doe
    July 18, 2011 at 6:41 pm
    What codec are you using (ProRes, AVCHD, etc)?
  • Everest Mokaeff
    July 18, 2011 at 6:52 pm
    I once had pretty hard time w/ My Book Studio Edition while working on location. Since then I’d never let it anywhere by me unless I’m really desperate.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
