Activity › Forums › Apple Final Cut Pro Legacy › Dropped frame on a DV tape – Is there any workaround to capture ?
  • Dropped frame on a DV tape – Is there any workaround to capture ?
    Posted by Ace Billet on September 5, 2005 at 4:10 pm
    I have a MiniDV tape that has some ugly drops, but ,most of the drops are in the audio.
    FCP stops the capture because of these dropped frames, but I want to bypass it.
    One solution I tried is plugging the camera via Analog (TV connection) to a DAC, and capturing
    from it. I’m sure some quality is lost here.
    Is there any way to get a decent capture ? I checked the tape on 2 cameras (both had the dropped frames),
    plus other tapes are captured OK.
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
    Mitchji replied 21 years ago 3 Members · 8 Replies
  • 8 Replies
  • Thaxter Clavemarlton
    September 5, 2005 at 4:21 pm
    Best digital capture bet is to just keep trying to capture the same small area over and over.
    One of the passes might prove to get (more of) what you need, then edit that good section in.
    If you can get the analog input to WORK, just edit in the missing small area (enough to not look or sound too “obvious” and the quality should be fine enough for “patch-work.”
    (Good grief, until just a few years ago EVERYTHING was analog and no one “passed out” from using the process!)
    September 5, 2005 at 4:24 pm
    AND…
    Switch the capture preset to “NON-CONTROLLABLE DEVICE” and just use “Capture Now” as you manually play the tape near and over the bad section(s).
    Do this numerous times until you (might) get a better-playing section into FCP.
  • Mitchji
    September 5, 2005 at 4:43 pm
    You can do a capture now with FW Apple or FW basic or which will capture the clip up to the bad frames. Then log and capture a clip that starts a couple of frames past the dropout. This is tedious but it will allow you to get everything except one or two frames.
    Another option that might work that was posted earlier was:
    “I prefer to use the basic DV capture utility in Sorensen Squeeze 3 in this sort of capture problem instance. It has no setting controls whatsoever, and seems to ignore a lot of problems that more sophisticated programs don’t – and it captures FCP-compatible QuickTime clips.”
    Best Wishes,
    Mitch
  • Ace Billet
    September 5, 2005 at 5:04 pm
    Well, the footage is about an hour long, with a LOT of drops (once every 10-30 sec),
    It’s supposed to look kinda grungy so I think i’ll just capture it all analog and process the video.
    However, I can connect either S-Video or “RCA” (Red, White, Yellow connectors) to the DAC.
    Which kind of connection will produce more * cough * accaptable results ?
    cheers
    ace
  • Ace Billet
    September 5, 2005 at 5:07 pm
    I remember having that kind of problem with a different camera.
    I solved this by capturing from iMovie (maybe has something to do with “forgiving”
    amateur drops ?) and importing the clips to FCP.
    Going to try that now ..
    cheers
    ace
    September 5, 2005 at 6:02 pm
    Hope the iMovie solution works.
    Back to the analog question.
    When given a choice, always go with true S-Video rather than composite.
  • Ace Billet
    September 5, 2005 at 6:12 pm
    Just captured the whole “dropped” tape vid iMovie.
    A lot of small clips (after each drop or cut) but at least DV.
    (boy that sounds amatuer)
    cheers
    ace
  • Mitchji
    September 6, 2005 at 12:47 am
    I think you will need to render the audio.
    Best Wishes,
    Mitch
