Activity › Forums › Compression Techniques › droplets wont import to compressor
  • Daniel Low
    March 10, 2009 at 11:01 pm
    As far as I know you can’t. Droplets are specific to your machine, cluster, network etc.
    If you want settings from somebody else, get them to send you a compressor setting and create a Droplet from there
    Fonts are like cologne:
    A bad choice speaks louder than a good one.
  • Lars Cuzner
    March 10, 2009 at 11:17 pm
    Ok, thanks Daniel. In that case, would all the necessary settings be visable in the droplet?
    And While I have you here…
    The compression I am doing is from PAL assets, the droplets are done by someone who is in NTSC. Should this matter? I mean, I am compressing for web, it shouldn’t matter right?
  • Daniel Low
    March 10, 2009 at 11:55 pm
    [lars cuzner] “In that case, would all the necessary settings be visable in the droplet? “
    Yes, if you can open and interpret them.
    [lars cuzner] “The compression I am doing is from PAL assets, the droplets are done by someone who is in NTSC. Should this matter? I mean, I am compressing for web, it shouldn’t matter right? “
    Yes it does matter, PAL and NTSC have different frame sizes and frame rates, you want to compress PAL to 25fps not 30fps, etc, keyframes and GOPs change too.
  • Lars Cuzner
    March 11, 2009 at 2:57 pm
    Hey Daniel, how would you feel about me emailing you that droplet and you telling me what is messed up from a PAL perspective? My email is lars@larscuzner.com
    Doesn’t seem to me that it carries enough information, but what do I know.
    Art films. I do all filming and post. Using Sony EX 1 and FCP 6.
  • Daniel Low
    March 13, 2009 at 11:36 am
    To look inside a droplet, right click on it > Show Package Contents and find the Settings folder in Resources. In there drag your settings file onto TextEdit.
    If you could copy and paste that here that would be great.
  • Lars Cuzner
    March 13, 2009 at 4:05 pm
    Here is one that is giving me some choppiness right now.
    From droplet:
    Do%2520not%2520use%2520on%2520aspects%2520other%2520than%2520specified%2520-%2520will%2520cause%2520picture%2520distortion.%2520Mimics%2520Apple%2520Trailer.%2520default-destinationmovyesyes01 2 3 0 Y 0 1 1 2-100avc11167360001no
  • Lars Cuzner
    March 13, 2009 at 4:39 pm
    well, that didn’t work,
    Try this
    or other suggestions?
  • Daniel Low
    March 13, 2009 at 7:19 pm
    That setting appears to be for AVC (H.264) at 1920×1080 – not PAL.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
