Droplet issue …
Howdy Guys,
Been googling and scratching with no luck to my problem …
WORKFLOW
– Created a multioutput Droplet in 3.5.1
– in Xcode created a installer so the settings go into user/library/application support/compressor and the droplet goes to the desktopAll install lovely and work a few times then I get the droplet has a circled cross through it and when you click on it you get
You Can’t open the Application because it is not supported n=by this architecture !
I am running 10.5 on my laptop and 8 core – same issue on both I need to reinstall compressor for it to work again …. not good as I am sending this to a client to use.
Any help would rock !
Cheers
MINTedit
London, EnglandMac Pro – 8gig ram – FCS 3 – CS4 – Cinema 4D
Film, Edit and Deliver
