Activity › Forums › Apple Final Cut Pro Legacy › droping frames
  • Posted by Steve Tamou on August 26, 2007 at 5:43 am
    I captured about 35 minutes of DV footage to FCP. I used the “capture now” button to do so. As I play the footage back in the viewer, it start off ok, then the sound becomes more and more out of sync with the video. I believe that it is droping frames but I don’t know why or how to fix it. Thank you.
    Randy Johnson replied 19 years, 1 month ago 2 Members · 1 Reply
  • Randy Johnson
    August 26, 2007 at 6:16 am
    you can test if it is drop frames by turning on the “warn of drop frames” option in the user prefrences menu.
    You can avoid dropping frames by lowering your playback resloution (rt playback drop menu in the top left corner of your timeline)
