Activity Forums Apple Final Cut Pro Legacy dropframes when capturing
  • dropframes when capturing
    Posted by Mike Armstrong on March 14, 2007 at 1:17 am
    Hi, this is probably pretty basic but it has me baffled.
    i’m logging & capturing miniDV tape (ntsc) from a panasonic camera i’m using as a playback deck. I’m running FCP 5.1.4 on a MBP. i’m capturing at ntsc 48 & am now having the problem that I keep getting an error message that says FCP has detected dropped frames & i have to restart the capturing.
    Can someone fill me in on why this might be?
    Thank you for any help.
    Mike
    “Rage against the Dying of the Light”
    Peter Dewit replied 19 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    March 14, 2007 at 1:19 am
    Are you capturing to a drive other than your built in system drive? Is that drive formatted Mac OS Extended? Are you using a firewire express card adapter, as all the firewire ports on ANY Mac share the same bus?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mike Armstrong
    March 14, 2007 at 1:34 am
    Hey Shane.
    I’m capturing to an external HD usb2 connected & it is MAC OSX extended. but i am using a firewire800 for a differnt HD & capturing via firewire400.
    Didn’t realize all the firewire share the same bus.
  • 13 Create COW Profile Image
    13
    March 14, 2007 at 1:39 am
    “I’m capturing to an external HD usb2”
    USB drives are not suitable for video editing they do hot have a fast enough continues data transfer rate for video.
    Capture to the Fire Wire Drive
  • Peter Dewit
    March 14, 2007 at 1:31 pm
    if all else fails you can capture to your internal HD then transfer to the external drive later.
