Activity › Forums › Adobe After Effects Expressions › DropDownList is not showing correctly in After Effects
  • DropDownList is not showing correctly in After Effects
    Posted by Miguel De mendoza on July 13, 2016 at 8:08 pm
    Hi, I’m having problems with the display of the dropdownlist. I’m building a preset list that way:
    var presets_list = presets_grp.add("dropdownlist", undefined, presets);
    “presets” is an array with some strings. When I open the dropdownlist in Extendscript it shows all elements:
    Even if I add new elements with that save button:
    But when I test it on after effects it only shows part of the elements, and when I add a new one it updates, the same problem persists:
    I can’t find anything in the web about this. Is there a known issue with the DDL in Ae CC? Is there a way to correct that behaviour?
    Miguel De mendoza replied 10 years, 2 months ago 1 Member · 2 Replies
  • Miguel De mendoza
    July 13, 2016 at 8:37 pm
    This is some testing code in other file, for helping propouses ;):
    function buildUI(thisObj) {
    var createPresets = function() {
    var presets = [];
    for(var i = 0; i < 10; i++) {
    presets.push("Preset_" + i);
    return presets;
    var win= (thisObj instanceof Panel)? thisObj: new Window('palette', 'Dropdownlist testing', undefined);
    var presets_grp = win.add("group{alignment:'right', orientation:'row'}");
    var presets_title = presets_grp.add("statictext{text: 'Presets'}");
    var presets_list = presets_grp.add("dropdownlist", undefined, createPresets());
    return win;
    var myWin = buildUI(this);
    myWin.center();
    myWin.show();
    Same result in SSTK:
    And in AE:
  • Miguel De mendoza
    July 15, 2016 at 11:39 am
    After two days tweaking all the properties of the list, trying all type of coding crazy things without any result, I decided to check the hardware.I saw that my gpu was at 86ºC, so I decided to remove it, open it and replace the termal paste of the chip. After rebooting the computer, !vualá! all works fine. Lesson learned.
