Activity Forums Adobe After Effects Dropdown List copy Layer to Comp
  • Dropdown List copy Layer to Comp
    Posted by Marcin Wiktorowski on December 6, 2020 at 3:45 pm
    I don’t know much about expressions and nothing about scripting – but I need help.
    So, please be understanding and explain me step by step what I should do(and where).
    I ve sytuation like this:
    – Comp_Main
    – Comp_Icons
    – Comp_3
    Inside Comp_Main I have dropdown List with Items.
    Items – this is layer list from Comp_Icons
    What I wanna do:
    When i select item no.1 from dd list – the leyer no.1 from Comp_Icons will be copied to Comp_3;
    when i select item no.2 from dd list – the leyer no.2 from Comp_Icons will be copied to Comp_3;
    …. e.t.c.
    Please help!
    Marcin Wiktorowski replied 5 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jerard Ghrandem
    December 6, 2020 at 7:01 pm
  • Jerard Ghrandem
    December 6, 2020 at 7:07 pm
    Hi Marcin,
    To control what you see on stage using a drop menu, you can use a Drop Menu Control effect and connect it using some expressions. There is a very good tutorial on this topic that could be useful to you: https://youtu.be/nPTNtwSx9SE
    I hope this helps.
    Jerard.
  • Marcin Wiktorowski
    December 6, 2020 at 11:47 pm
    Yes, yes, but NO!
    Yes, I know this tutorial very well – and I used it in my project. But it’s too complicated.
    Take a look at my project below.
    As you can see, there are 11 cities. Following this tutorial, I need to create 11 PreComps with items.
    It wouldn’t be that scary – but what if I decide to add another item?
    Any change I’d like to make, I have to do in each PreComp. (a lot of work)
    So I found a better solution.
    – Create one PreComp_Icons for all icons.
    – Create PreComps for each city.
    – Create a DDmenu for each city
    – When selecting a specific icon for a city – copy the icon from PreComp_Icons to Precomp_City (display).
    In this logic, I can add icons and items, and I won’t have so many complicated Precomps.
    But I do not know how to do it 🙁
    Exactly: I don’t know how to copy a layer from one composition to another after selecting in the DDmenu.
    December 6, 2020 at 11:50 pm
  • Walter Soyka
    December 7, 2020 at 2:26 pm
    I think you should use an Essential Graphics workflow to build a re-useable “Weather Icon” comp. With Essential Graphics, you can make that drop-down selector a property of the comp that can be modified and keyframed independently for each instance when it’s used in other comps.
    Check out the docs here:
    https://helpx.adobe.com/after-effects/user-guide.html/after-effects/using/creating-motion-graphics-templates.ug.html
  • Walter Soyka
    December 7, 2020 at 2:45 pm
    December 13, 2020 at 2:09 am
    YOU MADE MY DAY !!!
    This is exaclty what I was looking for !
    Thanks a lot !!!!!!!!!!!!!!!
