Activity › Forums › Apple Motion › Drop Zones in FCP X Effects
  • Drop Zones in FCP X Effects
    Posted by Doug Wells on January 25, 2013 at 7:43 am
    Hello,
    When you create an effect for FCP X, is it possible to have a drop zone not be effected by color correction or other effects? I am trying to create a simple picture in picture effect. I have an effect that I drop on a video track, then I can select the second picture as a drop zone. When the video plays, it moves one picture to reveal the other. The effect works fine, but I get the color correction on the video track. Is it possible to make the drop zone not be effected?
    Simon Ubsdell replied 13 years, 8 months ago 2 Members · 1 Reply
  • Simon Ubsdell
    January 25, 2013 at 9:40 am
    A published Effect will always be a composite once you’re in FCP X so you can’t strictly do what you’re asking.
    However you could make the your Motion project a Generator instead of an Effect which will mean your background won’t be included and hence you will be able to color correct it to your heart’s content (or add any other filters to your background layer).
    That’s assuming that you don’t need your Motion effect to influence the background clip in any way.
    If you do want to affect the background clip as part of the overall effect, why not publish some color filters from Motion for that layer (e.g. Color Balance, Gamma, Saturation, etc.) and then you will be able to control the color inside FCP X.
    You could also consider making this a Transition as this sounds more suitable to what you’re describing – but without more details it’s hard to be sure.
    Simon Ubsdell
    http://www.tokyo-uk.com
