Activity Forums Avid Media Composer drop shadow to keyed image?
  • drop shadow to keyed image?
    Posted by Kozo Okumura on September 10, 2010 at 4:14 pm
    Hello, I looked aruond the answer here for my question but I couldn’t find the answer yet.
    I made a key in photoshop or animate and export that matte key into avid and apply the video to it so. (for example, video inside start shape window) Now I would like to hava a nice soft shadow around it. Is there any way to do it without going to After Effect? I have an access to BCC and Saphire.
    Thank you.
    Kozo Okumura replied 16 years ago 3 Members · 3 Replies
  • Grinner Hester
    September 11, 2010 at 2:47 pm
    You can add it in photoshop as long as you don’t need to animate the shadow. Otherwise, yeah you’ll be going to after effects where you have much more control over the shadow and everything else.
  • Michael Hancock
    September 11, 2010 at 3:22 pm
    I know that BCC has a Drop Shadow effect that you can apply to Matte Key effects. Drag it directly onto the Matte Key effect (don’t Alt+Drag it to nest it – just drag it). It will replace the Matte Key effect, then in the Boris effect you choose to apply it to the TitleMatte.
    I believe Sapphire has something similar, but I haven’t used Sapphire effects in 4 years so I can’t remember.
    Michael Hancock
    http://www.oswaldcommunications.com
  • Kozo Okumura
    September 13, 2010 at 7:09 pm
    Thank you very much for your help. It did what i needed!!
