Activity Forums Adobe After Effects Drop shadow on Paint Effect?
  • Drop shadow on Paint Effect?
    Posted by Tim Johnston on May 25, 2012 at 1:42 pm
    This should be a quick one for one of you masters out there…
    I know there are lots of ways to do this, but what’s the best/simplest/most efficient way to add a drop shadow to a paint stroke?
    I’m ‘painting’ a lot of words onto a backplate. To separate them into different layers to manage them better, I put each painting on a different adjustment layer.
    Since paint is already an effect, applying the drop shadow effect to the layer doesn’t work the way I want (I want to add a drop shadow to each paint stroke).
    Pat Banahan replied 10 years, 8 months ago 2 Members · 2 Replies
  • Tim Johnston
    May 28, 2012 at 10:51 pm
    Thanks, Dave. I forgot about the ‘Paint on Transparent’ option within the Paint effect. If I do it on a solid, instead of adjustment layer, adding the Drop Shadow effect after it gives me the look I want – no need to PreComp.
    FCS 3
    AE 10.0.1.19
    ProTools 8.0.4cs2
    Mbox2Pro
    Matrox MXO2 mini
    OSX 10.6.6
    MacPro 2×2.7GHz
    8GB RAM
  • Pat Banahan
    January 9, 2016 at 10:38 pm
    Hey I’m having a similar problem however I want to add a drop shadow to all my paint stroked on a video clip – whenever I paint on transparent I only get a black screen can someone please help?
