Activity › Forums › Adobe After Effects › Drop Shadow missing, importing AE file into FCP
  • Drop Shadow missing, importing AE file into FCP
    Posted by James Mulryan on June 2, 2009 at 2:58 pm
    Hello All:
    I am loosing my drop shadow when bringing in a qt movie generated by AE
    Here are my settings
    DVCPROHD
    Animation
    channels: rgb + alpha
    depth: millions +
    color: straight (unmatted)
    Text looks great in FCP, but no shadow.
    Can anyone tell me what I am missing?
    Thank you.
    James Mulryan
    Sunset Park Media, LLC
    Santa Monica, CA
    info@jamesmulryan.com
    Adolfo Rozenfeld replied 17 years, 4 months ago 3 Members · 5 Replies
  • Roland R. kahlenberg
    June 2, 2009 at 3:58 pm
    I don’t think that the DVCProHD CODEC supports an alpha channel. Try the Animation CODEC at 92% quality setting.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Adolfo Rozenfeld
    June 3, 2009 at 6:46 am
    I think James means his Comp is set as DVCPRO HD. He mentions he exported QT Animation with RGB+A (why 92 percent?)
    James: Are you compositing this over anything other than FCP’s default black background?
    Adolfo Rozenfeld · Adobe
    June 3, 2009 at 7:14 am
    Thanks for jumping in Adolfo, I thought he had rendered with the DVCPro HD CODEC.
    I suggest a quick check within the Comp Panel to check if the correct (desired) Alpha Channel is visible prior to rendering.
    I’ve used 92% for the Animation CODEC for as long as I can remember and it’s served me well. Off course, uncompressed is preferred if storage isn’t an issue.
    Cheers
    RoRK
  • James Mulryan
    June 3, 2009 at 5:15 pm
    Thanks all
    Yes using animation setting.
    Using this comp as a graphics overlay on FCP DVCPROHD timeline. live action, not over black.
    Hate using DVCPROHD as an editing format, but my Matrox MXO and MacBook Pro will not handle Pro Res.
    Changed the straight matte to premultiplied, and now drop shadow is coming through.
    Looks a bit rough. Maybe my shadow is too thin.
    James Mulryan
    Santa Monica, CA
  • Adolfo Rozenfeld
    June 3, 2009 at 7:04 pm
    [James Mulryan] “Looks a bit rough. Maybe my shadow is too thin.”
    You may need to change the alpha type in Final Cut Pro.
    Right Click on clip > Modify > Alpha Type > Black
