Activity › Forums › Adobe After Effects › Drop shadow in specific Layers
Posted by Carlos Angulo on August 25, 2005 at 8:53 pmHi,
I would like to know if there is a way to make the drop shadow effect visible only over the alpha of specific layers?
Thanks.Aharon Rabinowitz replied 21 years ago 3 Members · 2 Replies -
Steve Roberts
August 25, 2005 at 9:34 pmYou could try duping the layer, then applying drop shadow as “shadow only” to the dupe. Then you add the layer on which the shadow falls, and dupe that. Use the dupe as the alpha matte for the shadow-only layer. Four layers instead of two.
You might consider making the layers 3D and adding a light, and set the shadow-receiving layer to receive shadows, and the other to cast shadows. 2 layers and a light instead of four … and more control over the shadow.
Steve
Aharon Rabinowitz
August 26, 2005 at 2:16 amHow about this-
Make a second layer that uses the shadow only option, place it below the original (that is “casting” the shadow) and then turn on its (the shadow layer’s) Preserve Underlying Transparency option so that it borrows it’s own opacity from layers below it. If no other layer is under it, it will be fully transparent, if a layer is under it it gets that layers level of opacity.
The Preserve Underlying Transparency option is an often overlooked feature. You can turn it on in the timeline’s “modes” pannel by checking off the little “T” box between the “mode” pulldown and “TrkMt” pulldown. Turn that on for the layer you are using as the shadow.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
