Activity › Forums › Apple Final Cut Pro › Drop shadow for FCP X
Posted by Nick Toth on July 5, 2011 at 12:45 amFor PIP drop shadow apply to a compound clip. Works fine applied directly to a graphic will alpha channel.
Nick Toth replied 15 years, 1 month ago 2 Members · 4 Replies -
John Spirou
July 6, 2011 at 8:36 amit doesnt work well with full frame clips.
I made compound clip , but the shadow is not right if you increase distance to maximum…. any solution ? -
Nick Toth
July 6, 2011 at 10:22 amIt’s working fine on my systems. For distance the slider goes to 100 but you can enter larger numbers to the right of the slider by clicking and typing in the number. This works in many effects where there is a slider – the range can be extended by typing in numbers directly.
NT
John Spirou
July 6, 2011 at 10:30 amcan you try without cropping-trimmingin a clip (PIP) and put the blur level + distance at maximum ?
Then try to rotate the shadow… in my system, the shadow is like cropped then . -
Nick Toth
July 6, 2011 at 11:20 amDo you mean try WITH cropping or trimming. That will cause the shadow to get cropped. You need to crop or trim first and then make it a compound clip and then add the shadow.
NT
