Activity Forums Apple Final Cut Pro Legacy drop outs on frames when exporting a sequence to quicktime
  • drop outs on frames when exporting a sequence to quicktime
    Posted by Philippe Muller on October 8, 2008 at 3:53 am
    Help! I must deliver a program of 35 fminutes very fast, all was OK, but…
    It’s a dvcpro-hd sequence.
    When I export it to quicktime ‘same settings, self-contained, no compression), I get one frame with drop outs about every quarter of the program (4 frames on the whole).
    When I playback the sequence, it’s ok.
    When I launch the export again, I still get dropped frames but in another places (about in the same area , about 4 times in the sequence). Is it a saturation issue ?
    The output was on the same drives unit as the scratch capture of the FCP.
    Thank you for some piece of advise…
    My config :
    Mac Pro 2 x 3 GHz Dual Core Intel Xeon
    Ram 8 Go 667 MHz
    Mac OS 10.4.11
    Kona 3 driver 4.0 (no conflicting files found)
    QuickTime 7.5
    disc SONNET : 8 Drives capacité 3,18 T disponible 2,6 TB Raid ATTO Express SAS R380 slot-3
    Test Fichier 2 GB write 440 MB /s read 125 MB/s (simultaneous Kona DMA
    Jaap Verdenius replied 17 years, 11 months ago 2 Members · 1 Reply
  • Jaap Verdenius
    October 8, 2008 at 8:03 am
    Philippe,
    Did you try export via Compressor?
    Jaap
