Activity Forums Panasonic Cameras Drop out problems with P2 footage
  • Drop out problems with P2 footage
    Posted by Anna Brownfield on February 18, 2010 at 12:58 am
    Not sure is this is in the right spot…but I’m currently editing a doco which was shot on P2 cards and I’m finding quite a few drop outs in the video footage…you know what it looks like, pixelated squares, which I can cut around, but the strangest thing is that at the same point it also takes audio from another part of the clip and replaces it.
    Has anyone else had this problem before and does anyone have any ideas how I maybe able to fix it??
    Anna B
    Anna Brownfield replied 16 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    February 24, 2010 at 4:30 am
    Main reason I have seen this…dirty connections on the card or the card slot. Clean out with canned air.
    Second, the card was inserted into a mac without the PROTECT tab switched over. Sometimes FCP writes files to the card that can cause issues.
    Bad news is that the damage is already done. You can’t fix it, but you can prevent it from happening again. Clean the connections, and always write protect the card when offloading.
    Shane
  • Anna Brownfield
    February 25, 2010 at 4:17 am
    Thanks for that. I always put on the right protect, but seems strange that footage transfered on two different card readers did the same…. but I’ll give them a clean for next time.
    Thanks again for the response.
    Cheers
    Anna B
