Activity Forums Adobe After Effects Drop into caustics tutorial. Troubles.
  • Drop into caustics tutorial. Troubles.
    Posted by Paul Whishaw on June 29, 2005 at 8:09 pm
    I am trying to complete the tutorial “Drop Into Caustics” but am having a bit of trouble. I am pretty sure I am following the directions but I am having no luck.
    First problem is that when I apply caustics to my bottom layer, it changes color dramatically. The tutorial says it shouldn’t change the layer but it definately changes. Next, my wave layer is grey. I have mimicked the file structure of the tutorial and it looks like the wave layer is left invisible. If I do this then I get no result at all. I have choosen the water surface file ro be the wave pre-comp.
    Obviously I am missing something.
    Is it something obvious?
    Derek Dockendorf replied 20 years, 6 months ago 3 Members · 2 Replies
  • John Ordelheide
    June 30, 2005 at 12:29 am
    Is your comp background or bottom layer black? I have sometimes had strange color changes when I have a layer at the bottom that is not black or white (when using things like layer modes.)
  • Derek Dockendorf
    March 15, 2006 at 10:09 pm
    I am having similiar problems as well. The Waveworld layer never changes from greyscale and has no transparency. I am using 7.0 trial could that have something to do with it?
