Activity › Forums › Apple Final Cut Pro Legacy › Drop Frame/slowness issue
  • Drop Frame/slowness issue
    Posted by Mike Petriano on April 26, 2010 at 7:25 pm
    Been working out of fcp7 on a new project at my office on (2 x 2.66 ghz dual core intel xeon) Mac 10.6 . Standard ntsc 3:2 settings. I’ve been running the project off of a lacie drive and it has been working fine.
    I brought the project home to work off of my laptop, which is a brand new mac book pro. I have fcp 7 on it as well. The only thing I had to do is re render the work because the render folder was on the main hard drive at my office (rookie mistake).
    I actually didn’t end up changing any settings or anything in the project, in fact, I didn’t even work on it, I just opened it.
    Today back at the office – I opened the project and it is unbelievably slow. It can only play back for 3 seconds before i get the ‘extreme dropped frame’ warning in red. Even opening the project took a long time.
    To test if it was the project/drive or if it was the disk, i opened up a different project from a different drive and it worked fine. I tried to copy the work onto another drive but once it hit the rendered folder, i got the ‘item xxxxxxxx could not be copied’ and the transfer stops. I’m running out of options.
    I made no changes to the settings in either the project nor to the disk.
    Any suggestions on as to why and how to fix this?
    Best,
    Mike
    [If I delete any changes that were made ‘yesterday’ (when the project was opened from my laptop) like autosaved, rendered, etc, will that solve the issue? Or would this make it worse?]
    Mike Petriano replied 16 years, 5 months ago 1 Member · 2 Replies
  • Mike Petriano
    April 26, 2010 at 9:03 pm
    Interesting. The rendered files aren’t offline… which, is slightly odd considering they were re rendered at home. But this could be the issue. I’m always nervous to use the media manager – I don’t want to dig myself deeper into a hole. What steps, using media manager, would I have to do to change the rendered files, without messing up the clips, timeline, etc – basically so I can still open it and re render the files if this goes wrong.
  • Mike Petriano
    April 26, 2010 at 9:08 pm
    Wow, nevermind. I was just working on other projects, reopened the one at issue, and it scrubs and plays back fine. The whole thing didn’t make any sense to me. I did however, repair my hardrive via mac utilities… maybe that had something to do with it. Thanks for your help.
    Mike
